gorilla glue
gorilla glue
gorilla glue
Jack Putnam
I am working on a set of coasters for drinking glasses and I want to put 1/8" thick cork glued to the bottom of a 1/4 thick birch plywood bottom using gorilla epoxy glue and I want to know if the epoxy glue would stick to the cork. Is there a possibility that the epoxy would absorb into the cork and not stick to the birch plywood. If there is any reason that the epoxy would not stick to the birch plywood and the cork is there another glue I could use? Thanks for any help on this project.
Re: gorilla glue
Re: gorilla glue
C. John Hebert
2 coats of contact cement would work much better
Re: gorilla glue
Re: gorilla glue
Bill Howatt
Epoxy will stick to a very wide range of material; it usually has most problems with plastics like polyethylene.
However, I think it is overkill and more messy than C. John Hebert's recommendation of contact cement. If you are putting it on an absorbent material which the cork might be, then 2 coats should be done as he recommended.
Bill
Re: gorilla glue
Overkill
If you don't like contact cement, Titebond II or III will do just fine as will any number of mastics. Got a partly used tube of pure silicone caulk or some aging ceramic tile adhesive in the paint cabinet? They'll stick your cork and be waterproof as well, and your plywood is more likely to delaminate before their bonds degrade.
Re: gorilla glue
That was my thought too
Cork and wood are porous. About any adhesive will fasten them together.
However, the thin plywood may cup if a water based adhesive is used. I would be inclined to use a contact cement.
