Cleaning plastic Eyeglasses?
I have plastic Eyeglass lenses that have some age and wear. I have ordered replacements and they will be here in a few days. It seems that merely ordering new glasses has made the wear and crud on my old ones more prominent. I don't have a spare set so when I take them off I can't see them well enough to be sure , but I think some of it is over spray from spraying lacquer and some is just wear and tiny scratches. I also suspect the coatings are coming off.
I clean them by running hot water over them and wiping them with a cotton towel. Sometimes I use hand soap and my fingers and hot water and the cotton towel. I also use the lens cloth that came with them after I rinse and dry them.
What else would be safe? How about that orange paint stripper? I asked the optometrist about lacquer thinner, but they appeared horrified and said it might take the rest of the coating off or even soften the lens. Anybody got good experience?
Re: Cleaning plastic Eyeglasses?
Kneale Brownson
Kneale Brownson
Safety goggles when spraying.
I clean using WARM water with soap, rinse well, soft cotton towel to wipe dry.
That's the trouble...
John in NM
Pretty much anything that will take off the overspray will likely attack the plastic lenses as well. Great argument in favor of glass lenses, though plastic has been popular for so long now that it is getting expensive and difficult to get glass ones made.
Plastic lens of today are usually polycarbonate material or similar. Unfortunately almost all solvents (all that I know of) that would remove lacquer or most other sprayed coatings would attack the lens material. I have some sanding / polishing disks that do polish plastic material (originally used to polish aircraft windshields, windows and similar material. However I am sure they would remove any protective coating applied to the lens and quite possibly change the optical characteristics. Sorry don't think their is any solution other than replacement.
One option I am exploring is to purchase a second set of "cheap" glasses from one of the sources that are always advertising the low cost glasses. I got a copy of my prescription from my optometrist, and am going to see if I can find a low cost source for a second pair. I just purchased a new pair last month @ $600, so am sure I can find some a lot cheaper for shop use!
Don Orr
I regularly clean my plastic (ploycarbonate) specs with isopropyl alcohol pads like they use for taking blood. Very cheap at the drugstore and probably identical to the expensive lens cleaning wipes-at least they smell the same to me. I have also cleaned CA glue spatters off with acetone with no harm. Just what I do, not a recommendation.
solvents and plastic lenses
Lenses are either acrylic or polycarbonate if they are safety lens. Lots of solvents will attack acrylic. Polycarbonate has some unusual properties when it comes to solvents. Flex a polycarbonate CD disk and add a drop of nail polish remover to the bend and it will explode into a zillion pieces(wear safety glasses). I would not recommend risking any solvent exposure.
That said I use Windex all the time for cleaning. Rinse first with water to ensure removal of all abrasive grit. Sprits with windex and wipe with paper towel. The paper towel will be abrasive particle free. I don't trust any cloth to be abrasive particle free. Warm soapy water is even better.
Even here in out of the way NE TN I can get a pair of glasses made the same day if I show up in the AM. Lens grinding machines are now practical for small operations to own and use. Two shops in town have them. Last prescription sun glasses I got made were about $100.
C. John Hebert
well....I guess I'm gona go off the chart here. I've cleaned the over spray on my plastic lenses with lacquer thinner and it didn't affect anything at all. Done it several times and use the same shop pair for at least 3 yrs now. I'm not advising to do so...just saying what I experienced with mine
Re: solvents and plastic lenses
Joe Mohnike
The Fresno VA uses a 50/50 mix of distilled water and alcohol works good. I also use a mix of 50/50 water and vinegar. No problems with either.
C. John Hebert
of course....I don't leave on to long, and wipe it with a clean shop towel.
Jason Roehl in Lafayette, IN
What I used to use...
...when I had glasses was an eyeglass cleaning solution available from major grocers and retailers, about $7 for a 4 oz bottle that lasted a good while (3-4 months, maybe?) I used plenty, too, being a painting contractor. The solution seems to be a combination of alcohol and something soapy.
The reason I suggest this is that I had a horrible prescription--on the order of -7 or -8 in each eye, plus astigmatism. Because of that, I would always get the high-index plastic lenses to keep them thinner and lighter. I would typically have them so scratched up after a year, but wear them another year because of the cost, at which point they were nearly frosted from the scratches. So, with my last prescription, I asked what they used at the optometrist office to clean glasses. My last pair of glasses (before I had PRK surgery about 2 years ago) lasted about 6 years, and were still less scratched than previous pairs were after one year. I definitely cleaned off LOTS of overspray in those years, too. If the overspray was stubborn, I would spray a lot of the solution on them, then let the glasses sit while I took a shower. More solution, then clean.
Also, always clean them wet, and always with cloth, never paper.
Jason
r payne
If you talk to an optician, she'll tell you the ammonia in Windex will attack any protective coatings on the lenses. And she'll really have a fit if you say you use paper towels.
I'd have glass if the weight was bearable. My eyes don't like the hi-index stuff either. A couple prescriptions ago I got talked into tri-vex (sp?) and I like it. More scratch resistant (and a bit lighter) than polycarbonate (or CR-39) without the annoyance of the hi-index.
ron
Thanks, Buying new ones has been interesting....
My prescription has always been one step beyond the current technology. As the technology gets better, my eyes get worse. Now they are suggesting they can fix them when I get cataracts. They can replace the lenses.
This time my prescription came out to be +8.5 for the left eye and +8 for the right. With an Additional 2.5 for the reading portion. They, Costco, only makes them up to +8, so they called the ophthalmologist and they agreed to adjust the prescription to +8. I was ambivalent, but they said if I did not like them I could return them and go elsewhere. When the glasses came, I could not see well to read with my left eye, and that's my dominant eye. They realized they had failed to adjust the "plus" for the reading part to compensate for the reduction from 8.5 to 8. They are remaking them and I am waiting. They should be here in a few days.
A pair cost me about $300 even at Costco. I ave never been able to afford sunglasses. And clip-on's weigh too much with this prescription. I squint a lot.
Rick Haverstock
Many moons ago when I got my first pair of polycarb glasses, the optician suggested that I use the anti-bacterial pump hand soap to clean them. Nothing strong enough to mess up the coatings, and the soap properties won't leave any kind of film to deal with. The soap also seems to get rid of the grease film from my sweaty face too. Drying only with soft cotton(old sock or tshirt) will not leave any scratch marks. Best of all, five bucks gets you 32 ounces of refill soap. Works very well for me.
Rick
Re: Chlorinated hydrocarbons
Chlorinated hydrocarbons are a disaster when used on or near polycarbonate (Lexan is one trade name of Polycarbonate). As an Engineer in a manufacturing plant several years ago, after studying the strength of plastic shields used on our machinery, I had some polycarbonate shields built and installed on several machines. The impact resistance, flexibility and strength were far better than the Acrylics previously used. After a few weeks, several of the "guards" started crazing and splitting in area's where screws / bolts attached them to machines (stress areas). The cause was traced to a lubricant dip tank which contained a grease thinned with 1,1,1-trichloroethane located several foot from the guarded machines! A few years later a major customer for our television volume control / off-on switch required us to sonic weld a Lexan cap over the steel shaft for electrical isolation. These were in the field for a few months when they found the cleaning products consumers used to wipe the appliances clean were attacking the Lexan and it was falling apart - this resulted in a recall (our customer was totally responsible as they had specified the Lexan ~ one of their own products!).
As this is the same material used for polycarbonate eyeglass lens, I am quite careful of any cleaning material I use.
Re: Cleaning plastic Eyeglasses? *LINK*
Lars Parrington
Prescription glasses can be had for cheap online. I pay ~$10 / pair for regular glasses. They come from china, but the quality is good.
Prescription safety glasses are a bit more expensive and harder to find. I picked up a couple pair from the link below for ~$40 each. They are so much better than trying to wear non-prescription safety glasses over regular eyeglasses in the shop.
For those prices, it is hardly worth trying to clean them.
http://www.greateyeglasses.com/shop/home.php?cat=31
