Willow burl -- Worth salvaging?
Lars Parrington
My brother-in-law just had a huge willow taken down in his yard. The bottom 3 feet or so of trunk were covered in burl. I know willow is not a good furniture wood in general, so is it worth trying to do make anything from this burl?
Re: Willow burl -- Worth salvaging?
John Veerkamp
A turner will try any burl at least once. Burls often have fantastic figure and color not found in the normal wood. If you don't want or turn, contact a turning club in your area. Someone will be sure to take it off your hands. If you are anywhere close to western Missouri I'd be interesdtd.
well, duh
Tom Sontag - St. Louis
It might be nothing special and it might be spectacular, but something that rare ought to be explored.
I sawed a willow log once and the lumber was knotty and boring UNTIL I HIT IT WITH SOME OIL FINISH, and then WOW! Willow can look great, kind of like elm.
Lars Parrington
Thanks for the encouraging responses guys. I should have framed my question a bit differently. I am wondering more about the structural integrity of the wood, rather than its looks.
I've already taken a slice off one of the burls and cleaned it up. It looks awesome even without any finish. However, even with 30% MC, it feels very light weight. Hoadley does list it as slightly more dense than white pine and poplar, though.
The guy who cut it down said it was worthless, no good for indoor burning, and that the logs will decompose quickly if just left sitting outside.
I guess I'll tell my brother-in-law to hang onto those burls. Think I have to cut them up at all while they're wet to allow them to dry properly? Or can I just let them sit in a dry place?
warp factor
The willow lumber I cut warped a LOT as it dried. Not sure if that steers your decision one way or the other, but I think cutting now versus later depends on what you expect to use it for.
