What screws for Green Lumber?
Bart Goldberg
Bart Goldberg
I'm building some outdoor planters from green (18% moisture) lumber (Black Locust). I'm planning to use pocket hole screws to construct them. If the wood were dry, I've normally use fine thread screws, but am thinking that for this green lumber, I've be better served by coarse thread screws instead. Anyone got an opinion?
Thanks
Bart
Re: What screws for Green Lumber?
Do they make Pocket hole screws that are corrosion resistant/proof?
I would be more concerned about them rusting out than the threads.
Also, working the black locust green is a good idea. When dry it about as hard as woodpecker's lips.
John Veerkamp
The gold coated screws from Hillman or Fastenall will work just fine and resist corrosion. Coarse thread it what you'll probably find.
Bart Goldberg
Bart Goldberg
Yeah, they sell both Blue-Cote corrosion resistant as well as Stainless steel pocket hole screws, but as it turns out, only coarse thread are offered in corrosion resistant versions.
I have used Black Locust for other outdoor projects before and it holds up to the weather really well, and yes, once dry, its very hard stuff.
Bart
I'd use stainless
I like the Robertson-drive stainless screws for this sort of job. I get them at the yard where they sell the ipe decking. Anything coated will eventually rust. Also, there's no particular advantage to fine pitch screws. If anything, they are inferior because they have so little wood between the threads. Without any facts and figures to back this up, I suspect that teeper pitches actually have more pullout resistance because they don't mince the wood so badly.
My 2¢,
Jesper, Denmark
Jesper, Denmark
When screwing into Black Locust, make sure you lubricate the screws. A little pot with linseed oil is good.
If you do not, there is a risk that you break long screws, and if not lubricated with something durable, you will never be able to un-screw them later.
nomenclature question
Jerry Gibbs
What is "green" lumber?. My understanding is that framing lumber can be sold with moisture content of 15-18%. If so, your question applies to all construction lumber that is not measured for moisture content. I would apply "green" to freshly cut wood that has not been dried by any means. Jerry
Ditto
Howard Acheson
I thing there may be some confusion here. The way I read the OP's question is that he is referring to "green" as to freshly cut and being highly wet. Some of the responses seem to be referring to chemically treated rot resistant lumber. I may be wrong.
If the question is about the proper screw for freshly cut wood, then any stand steel fastener can be used. I would probably used a galvanized screw if I was concerned about rusting. Stainless steel screws and not needed.
Bart Goldberg
Re: nomenclature question
Bart Goldberg
As I stated in my original post -the wood is 18% moisture - so not sure why there is confusion on nomenclature.
Bart Goldberg
Bart Goldberg
This is not chemically treated (aka Pressure Treated) lumber - its just Black Locust I bought from my local Sawyer.
Bart Goldberg
Re: Ditto
Bart Goldberg
Well, if both Mark and Ellis suggest SS, then I will not ignore such good advice! Thanks to all who responded.
Regards
Bart
Howard Acheson
That's what I thought. Some responses went down another path.
There is no need for special coated fasteners. Use the same fasteners you normally would. Except, galvanized fasteners would be a better choice for an outdoor application. You could use stainless steel but they are expensive.
