200+ woodworking book reviews
Short extension cord - locking vs non locking 6-20
Stephen Kirk
I wanted to move my jointer and the cord is about 3' shy of the receptacle. It is currently hooked up with L6-20 connectors, which is the locking form. I see I can get 10-15' extension cords, but they use the non locking connectors. Since moving a receptacle is tougher than changing some connectors, is there any downside to the non locking version other than the plug could be accidentally pulled out? The vendor only states that a 6-20 connector should be used, rated for 20A/250.i believe I went with the twist lock because it seemed safer. I'm in a one person shop, yanking on cords isn't much of a problem. I also know it's a good idea to keep extension cords as short as possible, as it could shorten motor life.
Re: Short extension cord - locking vs non locking 6-20
Kneale Brownson
Kneale Brownson
Go to an electrical supply house and ask for three feet of heavy duty cable and the type of ends you want. I'd go for the twist locks.
Bill Howatt
If I understand correctly, your machine has a twist-loc and your receptacle is a twist-loc. I'd to to a store and get a length of #12 cabtire which is sturdy stuff for dragging on the floor or wherever else and 2 twist-locs and make up the cord. If you change connector styles, aren't you going to have to change 4 instead of 2?
No, apart from pulling apart easier there is nothing wrong with the non-locking connectors.
Other possibly less elegant option is to get a length of #12 and splice it into your existing cord. If I did that I would probably solder the joints.
Or you could just replace the existing cord with a longer one. This would be good if your existing plug is removable.
Bill
I would just buy some 10/3 wire (extension cord material) at a local electrical supply house and assemble the lengths you want / need. ANY plug socket combination is safe and effective if it is UL rated for the amp load (or higher) you will carry on the cord. As I have almost all my shop equipment on mobile bases including my 3HP Unisaw, 5 HP planer, 4.8HP Minmax band saw, Joiner etc., I run them all on extension cords. None of mine are locking Plugs/sockets and I have never had any issues with inadvertent un-plugging.
