A55 Smoothing Plane
Will Enduro water based poly work over oil stain?
Alan Young
Alan Young
or do I need a layer of Sealcoat ie de-waxed shellac between?
Re: Will Enduro water based poly work over oil stain?
Re: Should If
The stain is fully dry. The oil carrier will act as a sealer to prevent the waterborne finish from raising the grain and lifting the pigment.
That said, you will increase the visual "depth" of your finish by using a coat of dewaxed shellac as a sealer/tie coat. Care, however, must be taken regarding SealCoat. I had an oil+shellac+waterborne finish develop cold checks requiring the piece to be stripped and refinished. In contact with Jeff Weiss, the Pres. of Target Coatings here in New Jersey, he informed me that the problem was cropping up with all the makers, and it appeared to be occurring with the shellac coatings that were not freshly mixed. He indicated the shellac that was more than 3 months old should not be used under a waterborne top coat in order to prevent the problem due to the esterification factor that seemed to be part of the cause.
SealCoat used to put a "born-on" date on their cans but stopped, so there is now no way to tell the age of that sample you bought at the big box store. Consequently, I no longer use it as a sealer/tie under my waterbased top coats. I'm well aware of Zinnser's claim of a 2 year shelf life, but when it comes to my finishes, I prefer to mix my shellac in small batches such that I use most all of what I mix so that I have complete control.
To be fair, part of the problem I had may have been due to the amount of shellac I used because I was using Dark Garnet to blend the color of different parts of a piece done in cherry. I now use much less shellac and add TransTint dye to actually get better toning with a much thinner shellac layer.
Robin Corell in Atascadero,CA
Alan, you will have to do a test. I've used General's HP poly over several different oil products, sometimes with superb results and twice with delamination issues. I would also suggest you do your test with the oil still wet as well as a test with it dry. I prefer the wet oil method and I've had great results with one combination of products. When you hit the right combo the results are great.
RogerInColorado
I've used GF Enduro Var over GF gel stain on three occasions with excellent results. In all three cases I let the gel stain cure for 4 days. The instructions call for 72 hours minimum, as I recall.
