Half Round Table - having some fun
Joe in a Cleveland suburb
Over the weekend I glued up three panels that will become the half round'ish top.
I took one board and cut out three sections that looked best (to me). Flattened one side of each with hand planes and jointed the edges with a plane. Used the (power) planer to bring them down close to final thickness. Glued'em up.
Took the glued up panel out of the clamps, scraped off some glue dribbles, and began to plane it a little using a smoothing plane. That was fun. The plane was working perfectly and I was getting super thin shavings with no tear out and very little effort. It felt as if I was planing butter. I had to make myself quit or else the top would become too thin...
I was using winding sticks and a straightedge to gauge/watch my progress. I still have to do the same to the top (show side) of the glued up panel. So far, I was only working on the bottom to practice planing and setting up/tuning up the smoothing plane.
Next I need to cut it into the half round shape. I'll use the bandsaw. I'm not sure If I'll just draw the shape on and cut it, or use a board with a pin to rotate on.
After I cut it, I'll likely use a scratch block to put a small half round profile on the edge of the table top. I did this with a couple Shaker round tables in the past and it worked well. Not sure how it will do on the curly maple though. I'll have to test it out.
Thanks for reading/looking.
This crappy iPad picture doesn't do the curly maple justice...
