Am I cooking my wood?
I have a green house I have used for drying wood (like a kiln) and it gets lift in there for later use. So the question is am I cooking it? Does it hurt it to sit in a hot dry environment for months or years?
Trick Question?
Sounds like a functioning solar kiln.
Go with it!
Probably not
DaleLenz
Need more information. What is the Relative Humidity range in the GH? My guess the GH has a dirt floor and a relative high RH.
It does have a gravel/dirt floor
I have never read the RH. I goes up to over a hundred degrees (F) on sunny days. I was just wondering if heating the wood on a daily basis would cook it out or ruin it over time.
The space was set up to help heat my house back in my solar heat phase. Had a passive water heater in it that worked well but the tank leaked after about five years and I did not replace it. Now the neighbors trees have grown up and shade it so it is not as effective as it was. I did dry a stack of walnut in it a few years ago and it worked well.
Re: It does have a gravel/dirt floor
Keith Newton
It would be hard to say without knowing the inside and outside temp and RH, but as a general rule, if it gets 25* hotter whether Summer or Winter, this would get it down to a lower KD number.
As for over heating to the point of making the wood brash , I think that needs to be up over 200.
It might be time to invest in a meter.
And one final reminder, the magic number to kill insects, is 133*, which may need ~145* air, for a day, to reach that in the core.
Re: Am I cooking my wood?
The only time the temperatures you are describing would harm wood is when it has a high moisture content. IE: if you put freshly cut wood in the greenhouse and dry it too fast, obviously you could destroy the integrity of the wood, checks /splits and other bad defects would result. Once the wood is stable, you certainly should have no ill effects - My Van has quite a bit of wood in the interior, temperatures exceed any you have described when it is left in the sun. I have seen no issues in any of my vans after 15 -20 years of use (except the finish deteriorates).
However the "high" temperatures would not be my concern, but the humidity swings during the cool nights and hot days would. I am sure if you measured the temperatures and humidity swings, you might be amazed at the differences. Greenhouses typically have very little thermal mass allowing for large swings in temperature, With a gravel /soil floor, I would be pretty concerned about the issue. Wood will "move" somewhat when the variation in humidity is extreme, causing warping and cracking.
I am sure not an expert, Bill T hopefully will give you better info. Everything I have read suggests the best storage of lumber is in an environment that is stable - temperature stability does normally increase humidity stability, while large temperature swings typically cause large humidity swings - a real bad thing for lumber.
likely not
I have stored lumber in the attic of a shed for years where it gets 130 degrees in summer. It runs about 5 %MC in the summer and suffers no ill effects.
It would be best to cover the top of the pile either with something or with junk boards. It is not good to expose lumber to direct sun in a greenhouse or in a field.
