corking
corking
corking
Howard
I made these trivets about 10 years ago and I need to make some more. They are made by gluing the 1/8 inch pieces to 1/4 inch plywood.
The 1/8 inch space between the pieces was file with a material that consisted of ground cork in a solvent based mastic it was called something like Corkit. I applied it with a putty knife and sanded the everything flush after the compound dried.
I am unable to fine this stuff that I had used. Any ideas what I can use in place of it?
Thanks
Howard
Re: corking
That's a pretty cool trivet
Howard in Toronto
Sorry I can't help you with your product search but thank you for that pic.
Howard
Re: corking
Re: That's a pretty cool trivet
Jim Toews
Have you tried looking at the companies that sell materials for building fishing rods? I've heard they have a product to use on filling gaps on cork rod handles/grips (or what ever they are called). Just a thought.
Re: corking
if it is a 2 part expoxy here is the link
del schisler
http://www.aimmexinternational.com/corkit
Re: corking
Re: if it is a 2 part expoxy here is the link
Howard
The stuff I used was not an exposure and I would prefer not to use an epoxy.
I need to sand it shortly after it hardens and the dust from freshly cured epoxy is a health hazard.
Thanks
Howard
Re: corking
William Duffield
Wood dust is a health hazard, too. Some species of wood are very toxic, or carcinogens (according to the state of California), or sensitizers that can put you in the hospital. You aren't using the right sander and the right shop vac if you're breathing sanding dust. You should also be wearing a fitted dust mask.
Re: corking
Clint Searl
Re: corking
Clint Searl
1. Drink a case of wine and save the corks
2. Grind them up in a Cuisinart
3. Mix with epoxy or polyester resin
4. Grout and sand
Re: corking
Re: corking
On second taught . . .
Drink the case and fagedabowdt da damn corks!!!
:D
Re: corking
TomD
I've built a lot of fly rods, and the material they used to use to fill grips was some kind of white lead concoction. Many people take the dust from shaping the grips, and mix with epoxy to fill the cracks. It doesn't look that convincing, so I ended up just using epoxy to fill the voids.
None of that will get what the OP wants.
I looked up Liquid cork and got a variety of cork flooring fillers.
I wouldn't worry about sanding epoxy:
1) You can just let it harden longer eventually it becomes pretty inert.
2) You product will be mostly cork anyway
3) The main toxicity is that it can cause an allergic reaction, for normal people this is pretty much unavoidable, eventually. But it takes a long long time. Some people are hyper sensitive, and many appear immune. Anyway, you can deal with most of that by just working clean.
4) You can use methods to remove the build-up that will reduce the dust. Chisels are good, micro planes, hack saw blades used like a file, on a diagonal. Coarse paper. If you are using an oil finish, etc... you can wet sand.
Re: corking
Re: corking
David Churnega
Have you considered sawdust and Elmer's wood glue. You can mix and tint it any color you want. the wood fiber in the mix helps pitting and it sands easily.
