Posting a picture
Howard
I'm trying to include a picture in the body of message with no success.
I tried copying and pasting but it does no work. The picture is nor on the internet.
Thanks
Howard
Posting a picture
Howard
Thanks
Howard
Re: Posting a picture *LINK*
mdclor
You will need to establish a Profile, then follow the directions for posting pix found in the FAQ section. You will probably need to resize your pix and those directions are also in the FAQs.
Pix uploading
Still will not work
Howard
I have a profile and putts sword on proper box.
File is JPEG and 50K
When I try to paste the Paste icon does not appear.
I am able to paste to an email so I assume I am copying the picture.
Any ideas?
Thanks
Howard
Re: Still will not work
mdclor
You will probably need expert guidance, but you should NOT be using "copy/paste". The way it is done is to "browse/link". HTH
look at my attached picture.......
Posting a PIC on this site is arcane the first time you do it but after that it is trivial. If you are set up properly your header will contain all the stuff you see in mine, shown in my posted picture. then just click "choose file", go find where your file is stored and click it. Do preview at bottom to see that all is well and then post
Significantly easier to use a URL
Kneale Brownson
Find some place to post the picture on the web--I use pbase http://www.pbase.com/, which costs something like $25 a year, but won't disappear in a couple years like most of the "free" websites--and then you don't have to worry about resizing.
Once you have something on the web elsewhere, just copy the URL and include it here using this formula surrounded by <>:
img src="whatever the URL is, including a .jpg at the end if needed"
For example:
If you right click on the image above, select "copy the URL" and then paste the URL somewhere else, like in a word document, you'll see how it works.
My screen is different
Howard
The problem is that when I open the post a message screen the Upload embedded file and choose file icons do not appear on the screen??
Howard
The reson your screen is different.....
You have not successfully completed the arcane registration process which only a computer Geek can understand. Go back and try again.
I have suggested before, and will again, it would make a lot of sense for there to be a process where persons like Howard and I could just send our information and someone that understands this site software would do the registration.
Re: My screen is different
Howard, you have a valid profile, so you should be seeing the smilies and text formatting and file uploading stuff in your message posting box. If the upload file button (or choose file depending on your browser) doesn't appear, then our system is not recognizing your cookie as a valid user. Go to Set Preferences and correct your username and/or e-mail address. They must match your profile credentials exactly, including spaces, upper/lower case, etc.
It does appear that you have logged on successfully as "howard", with the correct e-mail address, so apparently your cookie that governs your login to this board, on this browser, on this computer has been somehow corrupted or erased. Set Preferences should be able to fix this immediately. This is the first thing you need to do if the message form doesn't include the member perks.
Please contact me directly via e-mail or click the "Report Problem" link when you need assistance. Our visitors are very helpful, but when you report a problem via the link, it sends me your browser and OS information as well as other information that may help me help you better.
Please let me know if you have any further trouble. As Bill said, the system is quite solid and responsive to proper credentials. We used to have a more lenient system, but the way we do things now prevents the kinds of spam bots that used to plague us in the old days. I appreciate everyone's patience with these security measures.
Ellis Walentine, Host
TomD
Sounds like you are so close you will soon be able to use the Cadillac system. I like just using Flickr, because it is the same process for all the sites, but more important, I have billions of photos, and flickr keeps me organized because it carries just the tiny set of photos I regularly use online for various purposes. It also gives me some editing control I may not have if I actually ship the photos to a site. Some of that would work against me if I was doing long slideshows as some do.
