Have a question? Ask Woody!
Half Round Table - some progress
Joe in a Cleveland suburb
I've had a little time lately to spend working on my little half round table. With my daughter getting married this summer, doing chores around the house, and helping care for my elderly parents (suffering from dementia), there hasn't been a lot of spare time.
In the last few days, I've been able to get my jointer back together (thanks all), started to put finish on the base, and started to mill up pieces for the top.
Some snapshots of my progress:
We debated on what to use for the top. My wife decided she wanted curly maple, so maple it is. The width of the table is such that it will require about 2-1/2 of the boards. I haven't decided yet the best way to lay them out. Should the partial (slimmer width) board be at the back of the table, middle, front? Not sure yet... Suggestions? This little table is going to be up against a wall.
Thanks.
Re: Half Round Table - some progress
Tony - Memphis
Looking good! nice clean joints. I would be hesitant to post closeups of mine! I would probably put the skinny board in back. Not sure why though. One note - tiger maple shows show up pretty obvious - might be worth slapping on a coat of shellac before final prep to make sure the grain/curl are going to look ok. I learned this the hard way. The glueups looked good dry, but when I added finish, the joint was prety obvious. Thanks for posting. COngrats on the wedding and sorry to hear about your folks. That's tough. We just got back from vacationing with friends whose parents are in rough shape - they called him several times a day. Hang in there. Remember, sawdust is theraputic!
Tony
Jesse Cloud
The table looks great! The aprons really sing the way the cherry grains accentuate the curve.
Curly maple is tough to make into a panel. The figure is very distinctive and there is little chance of having the figure in two boards match.
Two approaches you might want to think about:
1. Resaw the wide piece and bookmatch the pieces. Not guaranteed, but you will have a much better chance of getting a good looking joint. Resaw the other piece and use excess from the other panel to laminate on the bottom of the first panel to build thickness if needed. The appearance of the bottom laminate is less important. As we say "Only babies and drunks will see it."
or
2. Put something contrasting between the two pieces, maybe even a strip of cherry. Maybe even work in a curve to match the curve of the base...
My mom had terrible dementia in her last few years. Caring for her was the hardest thing I ever did. Look into a local Alzheimer's group. The can share a lot of strategies for coping with the problems of dementia. Some really helped.
Thanks for posting.
Really nice, Joe!
When I had a couple three-piece tops of curly maple to glue up, I ended up putting the narrow one in the center. That said, I think I made that decision because the grain matches and figure matches worked better that way. I'd let your subjective judgment be your guide. That sure will be a tasty table.
don stephan
Mineral spirits is slow drying and will allow you to preview how the boards will look with finish. I'd second EW's suggestion, middle or back, depending . . .
Give Jeff Jewitt a hello from Cincinnati next time you pick up materials.
Looking sharp!
John in NM
That table is really coming together Joe, very nice work!
