miters
miters
miters
Brad Bransky
I'm just getting into small box making and have had no trouble cutting miters on the table saw with both the blade at 45 and using the miter gauge at 45 and the blade at 90. I've done well with walnut, cherry, and quarter sawn white oak.
However, I'm at my wits end (short trip) getting accurate miters with western red cedar. I can't get it right on at least one corner after repeated attempts and blade adjustments. I tried the router but it scared the bejeebers out of me.
Anyone have any ideas? Is it me or the soft wood? I tried 2X4 stud wood and got perfect miters.
Brad
Re: miters
Re: miters
Brad Bransky
Trish and I are going for a bike ride and I'll check this later.
Brad
Re: miters
Re: miters
Jim Toews
In my (admittedly limited) experience, softer woods require a clean, very sharp, quality blade. These are always good with any wood, but absolutely mandatory for softer woods. I can get decent cuts in hard woods with a less than perfect blade (i.e. with some pitch and reasonably sharp), but not so with the softer stuff. A shallow pan, soft brass brush, and blade cleaner made an amazing difference. Your results may vary.
Re: miters
Re: miters
don stephan
the hardness of the wood wouldn't seem likely to make such a difference. Perhaps the cedar sides weren't as parallel as the other woods. Regardless, if you have a good heavy plane the appropriate shooting board is very helpful to me. Make it accurate and shooting the miters will be quick and easy and you're not dependent on perfect accuracy on the table saw.
Re: miters
shooting board
The one shown in the cock beading post is ideal. However, if the sides are not parallel, which seems the likely problem here, you are still screwed unless care is taken to choose the reference edge of each piece.
Re: miters
Re: miters
I have had an issue with the board slipping on my CMS & other saws during cuts. Your issue may be that the board edge are out of parallel or your blade may be pulling the material into the blade as you are cutting (I think soft woods do tend to pull more than hard woods unless you have a razor sharp blade). You might try clamping the board before cutting or, as I have done, installing some self adhesive fine sandpaper to the area where the board is held in the fixture. I have some fine sandpaper disks I cut pieces from as well as the small rolls of adhesive backed sandpaper. Makes it a lot easier to insure the boards are not moving during a cut. I also installed some in my Leigh dovetail jig, later found Leigh had "improved" their jig by adding a rough finish to the clamping area.
Re: miters
Re: miters
Brad Bransky
Thanks Jim,
I only use Forrest WWII and regularly use Dawn and a bristle brush in very hot water to keep them clean. They are only sent to Forrest for sharpening and repair. So it's probably not the blade. But, you may be on the right track. I'm using a 30 TPI. Maybe I should change to a 60 TPI.
Brad
Re: miters
Re: miters
Brad Bransky
Hi Don,
I've been thinking about making a shooting board. Thanks for the idea. Perhaps now is the time.
Additionally, I wonder if I would do better on the band saw, although the tooth marks might be hard to sand out without changing the angle of the miter. hmmm!
I'll try it tomorrow and post the result.
Thanks,
Brad
Re: miters
Re: miters
TomD
Shooting boards are a good idea if your plane craft is up to it. While it is right and proper to get sucked into a vortex of fancy board making if you wish, my own board is two layers of mdf, and two cleats. Made it, worked fine, never found the time to get more into it. Probably had it more than 20 years.
While it is fun to get into chasing measurements, I had this job to do with my radial arm at one point, it was really close, so I shimmed the fence with a piece of masking tape. Been giving dead on nuts 90s ever since. It isn't ideal since I don't get the full length of the fence to where I put the tape, and if I need to cut a shorter peice I am out of luck. Still, it works great and I use that fence a lot. Point being maybe try a piece of masking tape to micro shift your cut, bot the layer itself, and the relative position on the fence will shift your results.
Re: miters
Try one of these *LINK*
Terry Quiram
When it comes to making miters for small boxes you cant beat a miter trimmer. You get absolute, dead accurate results every time. It takes the worry about being close. I have the Grizzly knock off and it works very well. I also have access to a man that owns an industrial grinding business and he keeps my blades razor sharp.
Miter trimmer
