Samantha's Dresser 12- cock bead the drawers
With spring chores it has been hard getting time. With garden largely planted and lambs sold I am having more shop time.
Cock beading
PIC 1
Cock beading has a practical purpose. It protects the fragile edge of a veneered drawer. Additionally, it frames the veneer to provide an attractive visual effect. Apparently in some quarters a half width cock bead is applied to the drawer sides and bottom. The approach I learned is to apply a full width bead to top and bottom and a more narrow bead to the drawer sides so as to not weaker the dovetails.
PIC 2
Before cock beading the drawer must be perfectly fit into the drawer opening. The first step is to saw a rabbit around the drawer one just spent a day making. It is well to be sure the drawer is oriented on the saw table properly. I like about a 1/8” thick bead.
PIC 3 , PIC 4
The cock bead strips are made from straight grained wood to avoid tear-out while scraping the bead. The bead profile is scraped as shown. The profile could be routed but I find that the bead looks more attractive when it has the minor irregularities of a scraped bead. After scraping I tidy up any lumps or burrs with a sharp, fine toothed file.
The scraper is simply a piece of scraper stock with an 1/8” half round filed into it with a chain saw file. After filing the half round it is essential to grind flat and polish both faces of the scraper so as to make a sharp edge. I find it easier to pull the thin stock past the cutter rather than the other way around.
It is hard to get the profile at the very end of the stock scraped well. To overcome this limitation I scrap a piece about 2” longer than needed and trim about an inch off each end.
PIC 5
Begin installation by driving an indexing brad into each end and the middle of the drawer edge. Cut the head off the brad to yield a sharp wedge point with the long axis of the wedge parallel with the drawer length.
Cut a piece of bead stock about 1/8” longer than the drawer, position it over the drawer edge and press or drive it onto the brad points to fix it in place.
PIC 6
Clamp this assembly in a vise and shave off the protruding end of the cock bead flush with the drawer side.
PIC 7
Scribe the shoulder position of the drawer side’s rabbit onto the bead edge. This scribe line marks the end of the miter that will be cut to accommodate the side cock bead.
PIC 8
Cutting the miter is a trivial task with a sharp chisel and a jig as shown.
PIC 9
Add a modest amount of glue to the drawer edge and the cock bead, reposition the bead on the indexing brads and clamp. I rely on glue to hold the top and bottom bead on.
Pic 10, PIC 11
The device shown, I think it is called a donkey’s ear for reasons unknown to me, is just dandy for trimming the miters on the drawer side’s cock bead. There isn’t much gluing surface here so I brad this piece on aided by glue.
As seen in PIC 1 a small facet is carved on the miter corner to relieve the sharp miter edge to complete the cock beading.
Re: Samantha's Dresser 12- cock bead the drawers
note
Several who have examined a drawer wonder at the dark line at the end of the dovetails. This line is the edge of the walnut veneer used to cover the inside of the drawer front.
I regard the dovetail scribe lines as an accepted part of drawer making. Other's results may differ. Personally, I leave the "makers marks" on interior surfaces. I think someone 100 years from now may delight in finding them. It is not my goal to reproduce the perfection of "factory furniture".
What appears to be a nail hole on the drawer side is indeed a nail hole from brading the drawer sides together so that the tails could be sawed together for each side. It will remain unfilled to challenge someone as to why half the drawer sides have this feature.
Kneale Brownson
Re: note:  Sneaky guy aren't you?
craigd
donkey’s ear
craigd
Re: donkey’s ear
Jerrico and my grandmother, Kempshall Mountain fire tower 1954. I see no resemblance to the miter trimming device.
Adam of Oakland
Adam of Oakland
Bill this is a remarkable piece of work, and well described in the photos. It must be very satisfying to see all 12 of these drawers arrayed throughout your workshop.
craigd
Re: donkey’s ear
craigd
The donkeys I've had didn't have floppy ears either but hey, if Walt D thought they did, who am I to argue? Apparently he wasn't alone, as there is the Kalanchoe gastonis-bonnieri plant, which has floppy leaves and is called the "Donkey ear plant". A variety of snowdrop "donkey's ears snowdrops". The Tibetan Khapsey pastry, some types of which are "Donkey ear shaped" (I didn't see the semblance there either). A donkey's ears cap (I found photos of ears up and ears down), a paper headdress similar to our dunce cap. It is a very common term, dating from the Greeks (if I can read correctly) so maybe our donkeys are different.
