Turner looking for pointers
Steven Antonucci
steven antonucci
I am primarily hanging out at the lathe, but ever blue moon or so, I work on the flat side.
Here is my progress on a drop leaf table I am working on. I am getting ready to connect the leaves to the top, and have two things I am leery about screwing up.
First, the edge of the top will have a bead on it and the edge of the leaf will have a corresponding cove to it that needs to align in the bead. Any tips or tricks to cutting them (handheld router vs. router table?) so that they match and the table surface is flush when opened?
Secondly, I have to set a hinge in to hold the whole thing. I bought piano hinges, but in looking at another table, I saw that they had use smaller hinges (2,3, 4?) What is traditional and how many would you advise if smaller on a 54" top? Any tips or tricks for inlaying them also appreciated....
Steve
Re: Turner looking for pointers
Re: Turner looking for pointers  *LINK*
Bob Entwisle in NJ
Hi Steve,
No experience here with a rule joint on a drop leaf table, but found this link, hope it helps.
Bob in NJ
http://www.woodcraftmagazine.com/onlineextras/RuleJoint.pdf
practice
Any tips or tricks to cutting them (handheld router vs. router table?) ...I have used hand held for this task.
I bought piano hinges...... NO! 4 traditional hinges designed for rule joints
The fit of all these parts is critical so that the joint does not bind. The quarter round and cove must be just the right size and the hinge location is critical to provide joint clearance. There are numerous articles and books on doing what is called a "rule joint". Practice this operation until you are confident of getting it right.
Re: Turner looking for pointers :Rule Joint *LINK*
Bob Entwisle in NJ
August 2012 Popular Woodworking had an article by Willard Anderson on the subject as well.
Bob in NJ
http://www.popularwoodworking.com/woodworking-blogs/editors-blog/positioning-rule-joint-hinges
Steven Antonucci
super helpful!  thanks
Steven antonucci
Helps to know it is called a rule joint...I had no idea.
Steve
Special hinge *LINK*
John in NM
As they've told you, a rule joint requires a special hinge. One leaf is bigger than the other so that the barrel of the hinge can be located in line with the step in the rule joint.
Many suppliers sell these hinges, but I'll give you the link to our usual favorite around here :D
Rule joint hinge
Dick Coers
The ideal fit of the rule joint hinge is that the joint is made tight, in both directions, when the leaf is pivoted up, but then clears the "male" part of the joint as you pivot it down. If you get it tight vertically just as the leaf comes up flush with the table, the leaf is supported the entire length of the table. Miss on that vertical position, and the hinge will have to take more load.
Re: Better Article *LINK*
William Duffield
I use the advise in this article from Woodsmith. Mine come out perfect.
You will want to use a router table, not a hand held router. Note that the bearing on the cove bit is not used. The fence determines the shape and fit of the joint.
Routing a Perfect Rule Joint
Steven Antonucci
thank you all.
Steven antonucci
I feel a lot more confident that I'll get this right...
Steve
Re: thank you all.
Roy Girolami
I admire brass hinges and use them when they are visible, but for this table, I would go with steel. They're hidden and the steel is a lot cheaper. i made a table years ago with the steel hinges and it is in use daily with no problem. You also need a support piece for the leaf when it is raised.
Roy G
