sawtooth shelving: screws? glues? screws & glues?
Adam of Oakland
Hi my friends - Tyro question about shelf supports here.
The span is ~28" wide between carcass uprights in the photo. I've milled 1/2" thick by 1,3/4" wide x ~80" long sawtooth sticks in the assembly. Doug fir, flat-rift sawn mostly. My question is whether you'd glue the sawtooth to the shelf carcass proper, or just use screws. Or would you screw *and* glue ala belt and suspenders.
My intuition says that 7 1,1/4" #6 wood screws should hold even the oppressive syllabus of my betrothed's higher education.
What say you? Here are some figures to help describe my position:
