birch tearout
birch tearout
birch tearout
Jack Putnam
I posted a message yesterday about getting tear out from drilling into 1/8 inch birch plywood. Well today it has escalated into something more. First I have the drill press set to the slowest speed and I have tried using a brad drill bit and a standard bit. I even tried to drill a small pilot hole to get it started and then drilled half way through one side and flipped it over and drilled from the other side. I am still getting tear out no matter what I do.
I wondering if you can drill that thin of plywood and get a clean hole. Thanks for any help you can give.
Re: birch tearout
Need clarification
Another case where a picture would be worth a thousand words. What failure are you labeling tear-out? This term has defined meaning when planing but I have never encountered its use in drilling. Is the hole coming out not round? Are the face plies separating from the core? Is the problem only on the exit side? How big is the hole attempted?
Drilling a 1" diameter hole in 1/8" plywood will not be an easy task. The face plies now days are poorly glued and will easily separate from the core. Drilling a 1" hole in something thin with a twist drill or spade bit will be impossible. Drilling through with any drill will be impossible without secure backing. Any gap between plywood and backing will enable the back ply to separate. Trying to get 1/8" in good contact with a backer will be a challenge. The outer circumference of the hole will need to be cut with a very sharp brad point or Forstner bit or the frail face ply will splinter.
Re: birch tearout
Fixes
First off, slow speed will make things worse. High speed in wood, especially plywood, is usually better.
Second there are several ways to minimize the issue. Masking tape on both side, like when you're cutting ply will help some. From what you describ, however, I think the best bet is to sandwich your workpiece between a couple of pieces of MDF and clanp it down tight, and use a good sharp brad point bit. The sandwich's "bread" will support the fibers in the ply and should about eliminate your problem.
Re: birch tearout
Re: birch tearout
Dick Coers
Another method since you can drill from both sides. Use that tiny pilot hole and then the right size brad point. Put the point of the brad point in the hole, and turn the brad point backwards by hand. Do the same from the other side, but then turn on the drill press and drill the hole. What you are doing here is scoring the veneer. As mentioned, high drill speed, slow feed. Other tips given will also help.
Re: birch tearout
I'm with Mark
Keith Newton
and was going to suggest clamping it between two boards.
Otherwise, in the absence of good sharp outside spurs, the hook angle, which in drills is the twist, is lifting the veneer on the top side, causing it to splinter.
A straight bit in a plunge router makes a good splinter--free drill. This can be a speedy accurate method, using a template guid bushing, when you have multiples, which I think you mentioned in an earlier post.
You really ought to consider giving more information about what you are making, to get the best responses. Otherwise everyone offering suggestions is just shooting out into the dark hoping to hit the mark.
