stack cutting
Jack Putnam
I would like to know if there is a better way to do stack cutting. I have a pattern glued down to two pieces of 1/8 inch birch plywood. I have put nails into the outside edge of the two boards one on top of the other and a nail in the center of the pattern to hold it together better. As I drill a hole through the two boards I put more pressure down with my hands so the two boards won't separate from each other.
Well I found out that it didn't help at all. I now have tear out between the two boards and the pattern is shot. I have no problem with just doing one board at a time but I wanted it to go a little faster. I have even tried to glue the outside edges together but that didn't work either. Thanks for any help you can give me. Desperate.
