Another use for a track saw
Jerry Gibbs
Most of us think of track saws in terms of sheet goods. I recently needed to trim an angled piece off the long side of a 40" 1x6. I laid the track on the end marks and quickly and accurately cut the angle. I don't have a tapering jig for a long rip, say 6', and it would have worked well there. It is not worth buying a track saw to cut tapers, but it is another use if you have one. Jerry
Re: Another use for a track saw
Jesse Cloud
There's another odd use - cutting veneer. I saw it on a Paul Schurch video and was skeptical, but it really works. He uses the metal cutting blade. You can cut a long sheet of veneer (or a stack of long sheets) into joint-ready pieces with one pass.
If you've worked with large sheets of veneer before, you will know thats a real game changer!
TomD
I have never made one, but there are some pretty neat plans for making your own, if you need one on a semi regular basis. To boot, with all the interest in CNC, there are sources of pretty good quality linear bearings, or designs for very good quality linear bearings, that can be assembled from parts, for not so much money. Ebay, or CNCrouterparts.
