Plaster repair. Any glue experience?
Gary Smyth
I've a disappointed neighbor. Leg snapped off. Newly broken. Very clean. No gunk. Leg part matches with no crumbles or loose stuff. Searched the internet and suggestions to achieve a decent repair are all over the place and vary from Elmers white, rubber cement, epoxy, superglue, burlap or steel or wood "splint" and new plaster, Bondo, and other real or imagined solutions.
The bear cub is a hollow table base with paws that support a top that has been on a open porch for many summers. Unless moved from its spot any pressure exerted will be to force the leg down right to where it snapped. I expect to "wash" plaster/spackle over any glue line and clean up some of the pock marks of past years. The base will not be carried by the leg, but it needs to hold. I'm hoping for a working solution that has lasted over time. Let me know.
Re: Plaster repair. Any glue experience?
Joseph Mulherin, sr
I might suggest using a concrete adhesive...paint it all around the break and the leg, let dry, then apply some of that wash plaster to the joint leg and place it in place. With the squeeze out wipe it all around the leg making a cove like joint. This should make the leg joint stable for another many years.
TomD
Epoxy of the type that sinks in like WEST 105 205 (sample size), should be fine. I repair stuff like that with epoxy all the time. Of course epoxy products are common in the masonry field. Epoxy will adhere to itself, so should it need further repair, you don't have that problem where the initial repair queers subsequent efforts.
Just checking
Gary Smyth
Joseph, for the concrete adhesive you are talking about the stuff that comes from a tube like calking, correct? Something like "Liquid Nails"? Is it specially formulated for plaster or is it different than what I have in my mind?
Tom, for the West stuff I have the red shaded 105/205 and even some 407 light filler. I'll call Gougeon tomorrow to see if what I have will do well and if they suggest the filler is needed.
Neither of your suggestions crossed my thoughts before your responses. Thanks guys.
Re: Just checking
Joseph Mulherin, sr
No, Gary, I was speaking of the liquid in a quart bottle. We used some of it on a stucco repair and it came out just fine and the stucco will never fall off again
Thank you, I'll look for it
Not my thing, but......
it seems to me you should talk to a potter. They stick stuff together with "slip" which is a thinned version of water and clay. Why can't you stick this back together with thin Plaster?
Re: Doubt that would work without firing
Potters do use "slip" but I don't believe it has any strength until it is fired in a high temperature kiln.
Re: Not
A given amount of plaster in a cast becomes a sort of crystal when it sets up. While new plaster will "stick" to old, the amount that would be left in a repair joint would be minimal and not effective. Broken castings are usually repaired using pins for reinforcement and a glue that can be absorbed by the material. The pictured piece shows a minimal thickness in the plaster cast which makes the repair unlikely to be able to support weight. If the fracture line can be accessed from a different direction laying in fiberglass and resin across the joint would be more likely to hold, but even that will be a fragile fix.
The real solution is to make a mold of the piece and make a new casting.
Re: Plaster repair.
Gary,
Since the leg is structural (weight bear-ing) and the plaster has been exposed to the elements for a period of time, you are dealing with something that is inherently weaker than when new. Plaster is not a very good outside material and acid rain etc. with break it down over time as you can see from the pitting already evident.
Since you're not in a position to make a mold and new casting, I suggest the following:
1. Cut/shape a piece of wood that will fit all the way into the broken leg and also extend down into the piece and rest on the bottom. The wood will be able to take all of the stress of support off the fractured area.
2. Mix some epoxy and "glue" the wood into the broken foot. To make sure that it fits, you want to do this with the piece "inverted" so the feet are down on a surface and the epoxy stays in the foot.
3. When the glue has set up, apply some shellac on the outside surface around the joint.
4. Mix another batch of epoxy that will have enough volume to fill the foot and spread out in the "belly" area. Invert the piece right-side up, and pour this mix into the casting. Reset your leg/wood in place. Now seal the outside of the seam with hot wax. Carefully invert the piece again so that all the feet are touching the flat surface. The epoxy will run down to fill the broken foot so that when it sets up it will be solid.
5. When set up (next day), scrap off the wax. The shellac will have prevented the wax from getting on the plaster surface so that your repair compound will stick to the old plaster after lightly sanding the surface.
PS: Spackle/joint compound will not hold up outside.
PS
Since the whole piece looks to be degraded after years of exposure, it's likely that this is just the "first break." You have the option of filling the whole item with expanding urethane foam which will add little weight by make the casting stronger. The stuff comes in aerosol cans as well as mix-n-pour kits of various volumes.
Re: Just checking
TomD
One thing that also works is acrylibond, it is an acrylic liquid (quite generally useful stuff) You use a bit of it in the place of water, with whatever the parent stuff is (cement, plaster) and it helps bond in the new work. But for this I would just use epoxy.
