ot dull lawn mower blades
Jerry Gibbs
Sharpened the mower blade and cut the grass for the first of the season. Amazing how dull the blade was and still cut last year.
Re: ot dull lawn mower blades
Just heard on a Lawn and Garden talk show that you should sharpen the blade every third mowing. I don't think so.......
Yeah, well...
...you should floss after every meal, too; maybe after every snack. If you did everything you're supposed to, you'd never get anything done.
Hank Knight
A dull blade shreds the tips of the grass leaves rather than cutting them cleanly. This leaves the grass more susceptible to fungus and other diseases. A lawn cut with a dull blade will have a dull or even a brownish cast in a matter of hours after it's cut, even if it is not diseased; while one cut with a sharp blade will look crisp and green long after it's cut.
Re: Yeah, well...
Ron in Sterling, CT
My Dentist told me "I only need to floss the ones I want to keep".
Ron
TomD
It is eye opening to re-mow a section that one had mowed just prior to sharpening. It can be an inch or so lower for the same setting.
Pete in Holland MI
Dull blades also require more horsepower to plow thru the grass, which relates to gas useage, and machine wear & tear. I've showed numerous neighbors over the years as they fight cutting heavy grass, the benefit of sharpening their blades for them, and can cut the grass a good speed, without stalling the engine. This usually entails walking up to them while they are mowing the grass, taking the lawnmower from their hands, taking it back to my house, sharpeneing & balancing the blade, then send them on their merry way. Gained several 6 packs, and a good relations with the neighbors that way.
Pete
Gary Smyth
Pete, You're welcome to stop by. I have two Cub lawn tractors with decks that are a PIA to mount and remount. Blades get a real workout and they can't be sharpened without disassembly from belts and then deck after it is pulled from under the frame. For me, once a year after leaf collection in the autumn. If mine are an indicator, your neighbors ought to provide more than a six pack ....but the gesture is nice none the less.
Jim DeLaney, Austintown, Ohio
I mow about 1¼ acres, and change the blades on my 48" mower deck about four times a season - about monthly. The old blades are always really dull/beaten up when they come off. I keep several sets ready, so I always have a sharp set to install.
Re: ot dull lawn mower blades - car ramps
Bob Entwisle in NJ
Gary,
I run my lawn tractor up on a set of car ramps. They raise the deck high enough that I can R&R the blades without having to R&R the whole deck.
I do agree that R&R of the deck is at best a once a season maintenance chore.
Bob in NJ
