Forstner bits
Forstner bits
Forstner bits
Jack Putnam
When using a Forstner bit and the wood starts to smoke a little bit would that be an indication that the bit is dull or just a tough piece of wood. If so can they be sharpened and how. If they can't be sharpened then I guess they would have to be replaced.
Re: Forstner bits
Re: Forstner bits
Bill Turpin in WNC mountains
Buy Colt Maxi forstner bits. They cut better, faster, and longer. They are well worth their inflated price. Cheap forstners are dull after the FIRST hole!
Re: Forstner bits
Re: Forstner bits *LINK*
John McGaw
Smoking is always a bad sign since it means excess friction. The bits can certainly be sharpened although, if they are cheap to begin with, they might not be worth the effort. I have touched up mine but have never done an extensive re-grinding of a far-gone bit. I use mostly Freud bits for all of the standard sizes up through about 2" and they hold up well although I also have a few weird bits for special purposes, for example a super long bit for making pepper mills.
Sharpen Forstner Bits
Re: Forstner bits
That means dull
John in NM
I sharpen mine all the time. The cutting edge is easy with a small triangular file, the rim is more difficult. For filing the bevels, clamp the bit in a vise for easy working.
I sharpen the inside of the rim with a wheel in a Foredom tool - a Dremel will work fine, or even a hand drill clamped down to the bench if you're good at it. I usually remove the burr that is formed on the outside edge by sorta "swipe-rolling" it on an oil stone.
Re: Forstner bits
they are execptional
I have seen them demonstrated at IWF in Atlanta. As a demo they bored a hole endgrain through a poplar log section and it bored as fast as flat grain. However they are ground they certainly cut well. I don't have any but if I need a bit that will be the kind I will buy.
I have some cheap ones and they get hot. And I have some better ones and they cut better but not close to the German bits.
Re: Forstner bits
Jack Guzman from Maine
Re: Forstner bits
You could be running them a little too fast. My forstners aren't the best but they work better at slower speeds.---Jack
Re: Forstner bits
Re: Forstner bits
William Duffield
Another excellent German brand of forstner bits is FAMAG BorMax.
The cheap Chinese bits overheat, destroying the temper, all too easily, especially if they are pushed too hard, or if thehy are driven too slow, or if they are allowed to clog with chips. The chips carry away the heat. My tactics are to drive them until the chips stop ejecting (or slow down), and immediately back them out to allow the chips to clear and air to circulate and cool them. My strategy is to buy cheap Chinese bits, and when I wear one out replace it with a BorMax.
The Colt MaxiCut bits have other advantages, especially if you are using them to make things like pepper mills. Their bit extension system is excellent. Easy to install, easy to remove and it centers very precisely. The chip clearing works better than any other forstners I have used, which means they have less tendency to overheat. They also make a #2 Morse taper attachment with the same extension system, for attaching the bit to your lathe tail stock. At this point, I guess you can imagine that they have a disadvantage: They're a lot more expensive than the Chinese bits, and somewhat more expensive than the FAMAG bits. Some sizes of the Colt bits are currently on sale in the Woodcraft online catalog.
Re: Forstner bits
Re: Forstner bits
Hank Knight
+1 for FAMAG BorMax. They are unstoppable,
Re: Forstner bits
Re: Forstner bits
Dick Coers
I bought a set of carbide tipped at Woodcraft at several years ago. The side spurs are really sharp and extend nicely so side friction is reduced. They were well made, and cut really well. No idea if today's bits are the same, but I swear by these.
Re: Forstner bits
Re: Forstner bits, end-grain tip.
Keith Newton
Let me help you with your wording. You said, "The chips carry away the heat." but you should have said, A properly sized chip takes the heat away. If there isn't enough power to take a large enough chip, or the operator just doesn't know, the small chip fails to take the heat.
These are wonderful drills, but I think they fall short for end-grain. What I like to do there, is to start the hole with the Forstner bit, then switch to a normal metal twist drill a little smaller. They do a better job of really hogging out a lot of wood, while clearing the chips. Then I put the Forstner bit back in to clean up the final cut, and to finish the bottom.
About 10 years ago, I was doing some sculpture, using a cherry stump which had the pith in it. While carving cherry green is wonderful, I knew there was a good chance it would check as it dried. As I was nearing completion, I the idea came to me that I might could bore a deep hole up from the bottom, to remove the pith and juvenile wood to prevent the checking.
I have a 2" F bit, but there was just no way to hold and drill a hole about 16" deep in those two monkeys. But I found that I could by starting small, then drilling progressively larger holes. It worked, and they didn't split, so it was well worth the effort.
Re: Forstner bits
Re: Forstner bits
William Duffield
There are good reasons I recommended them first, even before the Colts. I'm almost as much of a fan of 3/4" round dog holes as Rob and Vic, and as fond of Rock Maple as the crew at Bally Block. My original cheap Chinese 3/4" bit "bit the dust" in short order. I've been using my original FAMAG bit that replaced it for over a decade, and it still chews through maple like a horde of beavers.
As Keith suggests, it is important to have the right touch with all of them, knowing how hard to push and when to back off. It also helps to have the drill press handle in one hand and an air gun connected to a compressor in the other to clear chips and cool the bit.
Re: Forstner bits
William Duffield
Yes, good tip. It takes practice (and knowing what is going wrong) to get the right feed rate and rhythm.
I prefer brad point bits for drilling into end grain. To me, they seem to be better than other cutting geometries at following orders instead of following the grain. The big one I use for pepper mills is marked "Germany" and I think it is also a Colt (Miebach) bit.
Re: Forstner bits
Lots of good info...
John in NM
Famag's are my favorites of the ones I have, but after reading some of the comments about the Colt bits, I may have to try one of those too. Every Chinese forstner I've bought needed a bit of touch up before it would cut well, none of the Famag's, Fisch, or other premium bits needed any at all.
I do a number of long deep holes in end grain, but I found that forstners wandered enough that I switched to tri-spur auger bits for the deep holes. I usually grind the screw point down to a brad point though.
Re: Forstner bits
Re: Forstner bits
TomD
Commercials aside, if they ran well for a long time, and all of a sudden started smoking then sharpness is a likely cause. If they never ran in the first place, then you might look at issues that would account for that. If they cut well once, then a design change does not seem indicated. They are a lot like hand planes so a lot of the usual stuff applies.
Re: Forstner bits
Re: Forstner bits
I have a few sets - a Porter Cable set I bought at a yard sale (barely used) a Fisch set that are TIN coated and a cheap Grizzly set (I use bits from it when I think the material may damage the bit). I also have a couple of carbide tipped bits that work well. I normally run these in my drill press, using very slow speed, about 1/2 the normal speed for the diameter of a standard drill bit. I start the cut with light pressure until the bit has removed a 1/16 or so of material then really increase the pressure to remove large chips, backing out frequently to clear chips.
So far the only ones I have damaged or destroyed have been ones I used in laminates (Formica etc.) or fiberglass material. I knew this would destroy the bits so used cheap ones! I have sharpened a couple of the cheap bits - some didn't cut right new, using my Dremel on the inside of the spurs and edges only, then stoned off the slight burr, being very careful not to remove any material from the bit OD.
Re: Forstner bits
Rick L
Re: Wood Owl...Tri cut augers *LINK*
Rick L
are the best auger bits on the market.
http://www.leevalley.com/US/wood/page.aspx?p=63566&cat=1,180,42240
Lee Valley is the best deal going on quality drill bits for a reasonable price
Wood Owl Tri-cut Auger
