Only a question
Only a question
Only a question
Marty
I was wondering if any of y'all have ever used "foil faced foam board" for the primary ceiling in your shop? My shop ceiling is 10 foot high. It would take a "team" to hold up a piece of 1/2 inch plywood while screwing it in place. A piece of foil faceed insulation would be in oz's rather than lbs. Using the foil side down,I would get a reflective source of light, plus the insulation. Of course,the "Disco Ball" would be an optional item. Any pros or cons would be helpful.
Re: Only a question
alternative
Daughter just did a shop and the ceiling was done with 3/8" plywood painted white. The plywood had the "bead" profile every 2" simulating traditional porch ceiling.
Re: Only a question
Alan Young
Oh I just can't resist *LINK*
Alan Young
I don't know about the foil- But a readily available "team" can be rented
-Alan
Panellift Model 439
Re: Only a question
Re: Only a question *LINK*
mdclor
I used it once for insulation in an old house that had the 2x4's parallel to the walls rather than perpendicular as they should have been. IIRC it was R10 for 1" thickness which was better than nothing.
In answer to your question, I think it would be okay for a ceiling but anytime you touch it with anything, like the end of a 12' piece of stock you are getting ready to dimension, you will have a tear in the foil that will look unsightly forever, but it's "only" a shop. I suppose those dings could be patched with aluminum foil tape.
Another option would be to rent a drywall lifter, then you won't need to bring in the team. :D
Drywall lifter
Re: Only a question
Re: Only a question
I used 5/8" drywall, I also have 10 foot ceilings. I borrowed a drywall lift from a friend. They are not expensive ($180 at the following site) http://www.maxtool.com/troy-professional-drywall-and-panel-hoist/
or you can rent them. I would install roll insulation then drywall. If you don't want to finish the drywall with tape and compound, you can just add 1/4" thick X 2" or so, wood strips over the joints and screws and paint. The advantages of drywall are 1) It is fire resistant, 2) It is probably the cheapest material, 3) easy to install (with lift). 4) does have some insulating properties.
Tip: I installed a number of duplex outlets in my ceiling that are switched so I can hang light fixtures and just plug them in. I have a bank of 4 switches, 3 each control a bank of florescent light fixtures that span the shop ceiling - the 4th controls 6 incandescent porcelain fixtures that have 100 W halogen bulbs installed. This allows me to light a section at a time or the whole shop. I hung 4 foot T8 end to end across the shop and positioned the porcelain fixtures over machines. The Halogen bulbs do give a "sunlight" spectrum so colors / stains look like they would on furniture near a sun lite window.
Re: Only a question
Re: Only a question
Yonak
Marty, I did what you're thinking of in my work shed and haven't noticed any kind of problems. It's not the most attractive ceiling but it does add a level of insulation. I realize the reflective surface is supposed to be facing up to provide the best insulation but I couldn't resist the additional reflected light.
If you're swinging boards up high it will, no doubt get dinged, torn and broken.
Re: Only a question
Re: Only a question
ben d.
I used drop in ceiling tiles used in suspended ceilings and used rosette's from a house trailer supply with screws to attach it to the celing.
Works very well.
ben d.
Re: Only a question
Static cling?
John in NM
Seems like it would be a real dust magnet, in addition to the easy dent feature.
Personally, I like a drywall ceiling, but that pic Bill posted is really nice, I'd be happy with that too. Trick with those panels is to do a neat job, and that pic was a great example of tidy workmanship.
Man have drywall jacks ever gotten cheap! They were up around $800 when I used to borrow the neighbor's, and even then I thought they weren't too bad. The casters typically go first (being cheap :D ), the rest is pretty simple and not prone to breaking. I suppose the really cheap ones could be made of such light walled tube that you could bend them with some abuse.
Re: Only a question
Re: Only a question
John McGaw
I would certainly have some concerns about fire safety with essentially unprotected foam. That stuff can put out some lethal smoke and in large quantities. I guess that, if the shop was a detached building, it might be less of an issue but I had 5/8" drywall put up in my garage shop and took great care to seal every potential leakage point.
Re: Only a question
Read the label
Lee Schierer in McKean, PA
The aluminized foam I installed had a red printed warning on it saying that it should be covered.
Lee
Re: Only a question
Flammability
Mostly, that foam is pretty flammable, and most or all codes call for a barrier layer - 5/8" sheetrock is accepted in our codes. Even if your jurisdiction doesn't require a permit for your shop, it's a good idea; be a shame to lose all your nice tools.
I'll add to the dogpile of folks recommending a drywall lift. They are the bee's knees for what you're doing. Good ones come down low enough that you don't need to lift the sheetrock/plywood more than two-three feet from the floor to set it on. I'm 65, and I could use one to do a ceiling all by myself, if I had to.
Re: Only a question
Re: Flammability
Jerry Roberts
Shoot, make your own drywall lift. I did many years ago when I did my porch ceiling for the first time using drywall. Made a sort of 2x4 tee with a small plywood at the top. My wife helped me lift it but if yu measure real close it works just fine and a lot cheaper.
Re: Only a question
Re: Flammability
Marty
Well after reading the responses,I'll try a "lift". My "shop/garage" is a 2 1/2 garage,which is under a second-story loft. The flamibility aspect, I do not like. I do like the 1/4 inch beaded look. Thank y'all for the input. I'll see what comes up. When finished (LOL), I will TRY to show pictures.
Re: Only a question
Re: Flammability
Keith Newton
Marty, if you go with the beadboard, I'd suggest that you get a Wagoner paint sprayer. I used it down at my cousin's cabin. They had tried to roll the paint on in the bath, but had to spend a lot of time brushing to get it into the grooves, but the HVLP really was fast, and got it down in there. It will pay for itself on a job this size, in the time saved, if you count your time as $.
Re: Only a question
Re: Flammability
Curt Stivison
I used white metal roofing. It can be purchased to the exact size and is fireproof. The white surface reflects light and helps brighten the room.
Curt
