A55 Smoothing Plane
OT Cutting tile in place questions.
The house I just bought to fix and sell has tile floors installed by the previous owner or a handy man that worked for them. These are the typical tiles sold at Lowe's or HD in 12 x 12" size or 18" versions. The problem is the installer put them in to the "wrong" side of the wall at the doors. Instead of the tile stopping at or under the door, it continues to the other side of the wall and shows in the other room. How can I cut the tile back to the door? I know I can cut the middle part with a tile saw or angle grinder, but how can I cut right up to the jamb? The last inch or two?
Or would it be a better Idea to install a "threshold" on top of the tile to "fake" the appearance?
Re: OT Cutting tile in place questions.
Dick Coers
A Dremel with an 1 1/2" diameter diamond wheel will get you really close. Also oscillating tool with tile cutting blade.
Scratch and Snap
Dustmaker Mike
I would use method already stated, then pull the door jambs and scratch the tile and snap it off. You could use a chisel and tap the straight line then put a threshold over the top of it.
Justin Szeliga
Small masonry bit, drill a series of holes up to the jamb, the chisel it out, worry the edge smooth with a carbide drill bit, or use a threshold that lips up over the tiles to hide the cut line.
& use a Sears shopvac, operated by another person, to catch dust as you cut the line across the doorway
