bandsaw blowup
bandsaw blowup
bandsaw blowup
Jerry Roberts
Today while working on a project for one of my daughters I started up my Jet 18 in bandsaw. All of a sudden it made one heck of a noise and came to a stop. Now what? The top tire came apart and the almost new 3/4 in blade hit the frame and really bent the heck out of it as well as several teeth. So now the project is on hold till I get a new tire and new blade . Its only money I guess. Im not sure what I may have done wrong except maybe leaving the tension on it for several weeks. Always something.
Re: bandsaw blowup
Re: bandsaw blowup
Hmm. Tension on the wheel shouldn't have caused the symptoms you described. It sounds to me like the tire might be the culprit. Have you spoken with Jet about this? I don't know of any tire recalls or other reported problems, but maybe they can help you, especially if there's any warranty left on this machine.
Ellis Walentine, Host
Re: bandsaw blowup
Re: bandsaw blowup
Dick Coers
I haven't released the blade tension on my Minimax S45 for 25 years. Had you watched the blade and what position it was running on the wheel? Had you pulled back on the wood while the blade was running? If you pulled the blade off the wheel, it's going to make a racket. Was the tire in one piece? No idea what the deal is with it.
Re: bandsaw blowup
Re: bandsaw blowup
Bill Howatt
I only released the tension on my 14" bandsaw when it was new. Over the years I got lazy and the only time it gets released now is when I change a blade and that is very infrequent.
Bill
Re: bandsaw blowup
Re: bandsaw blowup
Larry U. Verhoff
Jerry IMHO for what it`s worth I think you had a problem with the tire, as long as you did not have wood in the blade and did something like another poster said, pulled back on the wood, that would diffinently cause it . In all my days, and there have been a lot of them, I have never seen or heard that happening. How old is the tire for one thing? If not very old, then like Ellis said, I would call Jet. Good Luck, Larry
Re: bandsaw blowup
Re: bandsaw blowup
Jerry Roberts
The warranty is probally long gone as the saw is about 5 or so years old. I had just turned it on in preparation of sawing but before I could do anything the tire came apart in pieces. Don't know but it looks like it may have dried out as it was not soft at all. I bought it new .. Im sure I cant save my Timberwolf blade. My shop is in an un heated or air conditioned garage and sometimes in the summer I have a problem with rust. Just one of those unexpected occurances I guess.
Re: bandsaw blowup
Dried Out Tire
Howard Acheson
A dried out tire is the probably culprit. Power tools are shipped in containers that get very hot during ocean voyages. This dries out natural rubber tires on band saws. causing them to have premature failures. If one tire has failed, it is likely that the second has little life left. Replace both.
Re: bandsaw blowup
Re: bandsaw blowup
One thing I would do is to make sure you don't have a wheel seized up since you said you have a rust problem. I would remove the blade and tire parts, then check your upper wheel to insure it is free. Then I would turn the power on and check that the lower wheel powers up ok. Replacement of the tires is not a major job, but I would certainly make sure everything else is ok, including that the blade is free in the guides and that any guide bearings are free before restarting the saw!
Re: bandsaw blowup
Re: bandsaw blowup
Richard McComas
Talk to these guys. The did a set of wheels for my 16" walker turner band saw 18 years ago. There still good as new.
http://woodworkerstoolworks.com/services/items/show/26.php
