computer question- "Live Update"
A small popup that scrolls up from the bottom right corner of my screen has recently started appearing. It asks me if I want to do something involving "Live Updates" which I learn is some tool from Symmantec. I have no idea where this came from as I have never used this product. So, how do I be rid of what ever is going on. I am wary of clicking on these things.
Re: computer question- "Live Update"
Bill Turpin in WNC mountains
Try this: Open control panel, open internet options, under Browsing history, click Settings, click View Files. This will open a list of all the cookies on your computer. Search for anything with symantic in it. Right click it. Select Delete. If warning pops up click yes. Bad cookie should be gone. Look for more items with symantic in it. Close the Files box, click OK twice. Restart the computer. Done.
tried it
so that is where cookies are stored, didn't see any from Symmantic but there were lots from Woodcentral
Hoa in Alameda
I hate this - some programs sneak in when you install some other programs, and try to sell you something, most of the time useless.
Do this: Control Panel -> Program and Features
If you see anything related to Symantec, click on it to uninstall.
In fact, you should check that right after installing/updating any program (you can have the list of installed programs ordered by installation date) and uninstall anything that you don't want on your system.
correction
found a disguised cookie and killed it along with about 1000 others. Have not seen pop up lately.
Re: correction
You get cookies just about any time you visit any website. WC stores your password and ID info in one, desirable. Many sites track where you go, may not be desirable. You do not have to load programs to get them, just use your computer. Shutting down all cookies makes often visited sites to load slower. Kinda damned if you do and damned if you don't! Glad this helped.
Re: Mozilla Cookie Manager?
TomD
I would regularly delete cookies, but as you say it means a lot of trouble visiting locations for which they are required. What i would like is a file into which I could store cookies I actually wanted and then dump the rest. Normally if one can think of anything, someone else has already invented it, the only problem being downloading the one that won't kill one in some other way. Anyone know of anything?
Bill Howatt
Have a look at CCleaner; there is a free version.
It will clean the temporary unneeded files off your disk, empty the recycle bin, delete cookies, etc.
It also has a setting to selectively clean cookies. The easiest way is to have it delete all your cookies. Then go to a site you want to store the cookie for such as WC. Go back to CCleaners cookie management area and transfer the WC cookies over to the "keep" side. Do this for each site you frequently visit.
When you run CCleaner now it will not delete the ones on the "keep" side.
It also has a registry cleaner included that is pretty safe to use since it allows making a backup for cleaning the registry and it does not do a deep cleaning so problems are very rare, if at all. I normally don't run it much since I consider registry cleaning to be over-rated as a performance tool and deep cleaners usually cause more problems than they cure.
Bill
Jerry Nicholson
Do you use Norton Antivirus? Norton is owned by Symantec.
Jerry
Yonak
Find something identifiable about the pop-up and do a Google search on that. It may turn up something useful.
Regarding Bill's mention of his registry cleaner creating a backup, it's a good practice to create a restore point before you do anything that changes the way your computer operates so you can go back to before the change if you need to.
Also, you may want to check out the startup tab on msconfig.exe to see what starts running when you start your computer. Be cautious not to start eliminating processes willy-nilly. Some may have to run and may screw things up if you stop them. If one looks suspicious and you don't know what it is, you can Google the process to see what it does.
TomD
Thanks, I use Crap Cleaner, but didn't know I could do that with it. I will give it a try. I don't mind blowing everything up, but it gets tedious to do on a regular basis.
Stuart Johnson
You might also check your browser add-ons and see if something has been added that your don't know.
