Re: Re-sizing bandsaw blades
TomD
Safety silv flux and solder is good stuff. I buy the flux locally but often get the solder off ebay. Be careful not to get the stuff with Cadmium in it (safety silv doesn't have it, that is the safety part) Though for rare use it probably doesn't mater much. Another option if you deal with brownells is silver solder tape, it is a ribbon of material designed to fit under sights, and ribs on guns. It is great where you want to use less heat than would be required to actually draw silver in from a rod held to the side. It also pretty much guarantees you will get an even distribution in the joint (I am assuming that you grind in a scarf joint, I don't think you can butt joint a BS blade with silver solder, but if you did, you wouldn't need much joint penetration and therefore tape would not be a big help).
Learning to silver solder is a great technique to learn, and allows one to make various tools using stuff like HSS that can be heated way up there with no loss of performance.
One normally wants an OA torch for this kind of work, because seemingly paradoxically, one wants to use the lowest heat possible, and hotter torches make that possible. But with small projects a propane torch is fine. I made this bike rack with a propane torch, before I ever got an OP torch.
