My dad bought a Rigid 14" bandsaw some years ago. It has never had a new blade on it. When I closed my cabinet shop 4 years ago do to illness I sold my 20" Delta. I am in need of a bandsaw now to do some small work I have, and can't find a replacement blade on line anywhere for this saw, or the actual blade size, which I don't believe is the same size as a Delta 14" Anyone know what blade length it is. Not really my choice of a saw, but I don't have the extra to get a good used/ or new saw right now so it is going to have to do for a bit.
(This suggestion assumes it's a two-wheel bandsaw) Open up the blade guards. Measure the wheel diameter to confirm that it's 14", then lower the top wheel as if putting on a new blade. Measure the center-to-center distance between top and bottom wheels (this will probably be easiest to do if you remove the table); put another way, the distance between the centers of the axles of each wheel.
Armed with this information, calculate the circumference of your wheels, using the old "pi times diameter" formula you learned back in Jr. High math. Add to this figure twice the distance between the wheel axles. This will give minimum blade length. This would be really hard to install, so add an inch or so.
If the saw is a clone of the classic Delta design, which most 14" saws have been for years, it probably takes a 93-1/2" blade. If your calculations come out close to this, that's probably what you need. If so, you're in luck; these blades are very common.
If this is a three-wheel bandsaw, you'll have to "lower" whichever wheel tensions the blades, and then run a tape around all three wheels to get the length. The ideal tape measure for this is one with a 1/4" tape, as these narrow tapes are flat instead of cupped. Overlap the tape a bit and read the length at the 1" mark, then subtract an inch.
If you find the calculated length is not one a common length, you can get blades made up. Look in your yellow pages for "saws," and see if there's a local business that makes up bandsaw blades. They can make a blade to any length. If your area doesn't have one, you can find several businesses that offer online services. One of them is local to me, and I've had good experiences with them; linky below.
Looked up through Google at Home Depot. The saw is discontinued, but the specifications list the blade as a maximum of 93.5" and max of 3/4" wide. Same as all the other clones. Probably the most common blade out there. they have them at Lowe's and Home Depot, but there are many other places to buy them and get better blades than the stock ones. Personally, I would put either a 3/8 or 1/2" blade on it as my go to blades for general work.
What I do is if I have a blade that fits already, but is dull, which is why I want a new one, I break it, and measure the full linear length. This eliminates any guesswork and gives one a perfect measure. Write that on the saw in indelible ink.
Normally breaking the blade is the first step to auxiliary uses like bowsaw blades, scrapers, strapping etc...
