A55 Smoothing Plane
PM PJ882 Parallelogram Jointer...
Derek Arita
For those of you that have one, I'd like to know if the tables hold their adjustment very well. I got mine just before a move. Two years later, I'm just getting around to adjusting the machine to use. I will have to move the machine every time I use it, so I was wondering about the talbes holding their adjustment.
I lucked out and the outfeed table is in perfect alignment with the blades, so I have the table set at around .010 above the blades. I'm going to be adjusting the infeed table to the outfeed table. I found it's pretty far out, so this should be fun. I just want to know if I make normal use height adjustments to the infeed table, will it hold its coplaner adjustment to the outfeed table? I'm asking for actual users, as that would be the most applicable.
Re: PM PJ882 Parallelogram Jointer...
Billv in Belleville MI
Personally I would break this into two separate items: are the tables align in the same plane, and is the height of the knives in relationship to the out-feed table correct. I don’t have a Powermatic jointer, but the Delta DJ-20 which has the same parallelogram design that allows the tables to move vertically and stay flat while maintaining a small gap between the cutter head and tables. Yet to upgrade my knives to a spiral cutter so usually each piece that matters gets a final handplane/scraper pass.
Had the other designed jointer which worked great except for the simple fact that I am a bit lazy, and the time to move the in-feed table is in seconds on parallelogram design. Plus with worn-out back and knees the hand-wheel adjustment was getting a pain. I tend to use hard, figured and pieces typically less than 4 feet so light cuts are just a common as deep ones. I use my jointer equally for face flattening boards as well as squaring them so using the entire deck is important.
The factory typically sets the tables to be in the same plane at the factory. If you have a high quality/precision 36”-48” steel rule (Starrett or Lee Valley) set it flat on edge with the use of some feeler gauges to guide any adjustments. It is a two-step process: out-feed to cutter body and out-feed to in-feed table.
Two rigid control arms support the in-feed and two rigid control arms support the out-feed table on the DJ-20. Your cutter depth height adjustment arms are attached to the outmost control arms. Those rigid arms pivot on shafts which are about 6-8” long. On the DJ-20 there are eight eccentric bushings (4 for in-feed, 4 for out-feed). As you rotate those eccentric bushing slightly changes the effective length of the parallel control arms. Loosening the locks screws and use a spanner wrench to rotate those eccentric bushings. As you rotate those eccentric bushing slightly changes the effective length of the parallel control arms.
I have adjusted mine twice in fourteen years which was due the Allen lock screw being loose and me lifting the table to move the jointer around in the garage.
How to adjust: Don’t use the knife edge as the reference; use mass of the cutter body. Knifes heights are adjustable and can nick you or the steel rule. Start with the out-feed side. Lower the table until the cutter body contacts the steel rule. All parallelogram measurements should be within 0.010-0.005” of a feeler gauge. Think three point contacts: cutter head, out-feed table two inches from cutter head and at the end of the rule. Measure the straightness at the inside and outside edge and then measure a crisscross (X) pattern. If they are not in the same plane then loosen the set screws and rotate those eccentric bushing slightly. Remeasure everything again and again until the three points of contact are flat. Perhaps you can get it flat, but if I was under 0.010-0.005” or less on inside/outside/middle and crisscross that seemed good enough.
Part two raise the outside table so the cutter head is now out of the equation. Level the in-feed to out-feed by raising the in-feed you can side a feeler gauge under the front edge of the out-feed. Then move the rule to have three contact reference points (1-outfeed: 2-infeed) Loosen and adjust the eccentric bushing slightly so the in-feed is now coplanar with the out-feed side.
To me the in-feed table height is absolutely irrelevant. All the in-feed table does is determining the deep of the cut. Knifes to out-feed height is where you want to concentrate. That height difference does vary but I believe I run mine with the knives about 0.003-0.004” higher than the out-feed table. In reality the only thing I bring out a dial indicator out for is insuring the knives are all installed at the same height. I set the out-feed to about 0.005” below the knives and grab two three foot boards and joint them at the same time. Place the jointer faces together and see if there is a gap of light in the ends or the middle. Concentrate on holding those boards tight on the out-feed table during this procedure. Move the out-feed table slight up/down and rejoint those same two boards. Once the gap of light disappears then the jointer is good to go for edge squaring.
To check if I have the knives all correctly installed I then do the same experiment on the inside, middle and outside and if the gap of light does not appear than the jointer is tuned perfectly in my book. Then lock the out-feed table tight. The DJ-20 has lock bolts on the back which restrict the out-feed range which second as a locking device. Then make a final pass with the twin boards because that procedure can cause the table to move.
