Samantha's dresser 12- drawer assembly and fitting
It has been hard to find time to work on this project with spring farm chores and wildflower hikes.
Drawer Fitting and Assembly
When we left off this discussion the drawer fronts and backs were final fitted to the case openings. The drawer side heights were also fitted with any error on the too big side, yet they were small enough to just slide into the opening.
Next the drawer is dry fit and slipped into the case opening. It is not uncommon that I need to shave a bit off the drawer side height at this step and maybe adjust the height of the back as well to get the drawer to slide in. Final fit of these heights will occur after the drawer is glued, when needed.
PIC 1 Gluing
The objective at this step is to get glue on all the mating surfaces and these mating surfaces together before the glue begins to thicken from drying. I use liquid hide glue for this step because it “lubricates” joints that slide together and it has a long working time. It is no more or less reversible than traditional Titebond, but it is less grabby on sliding joinery.
I believe that with all the technical resources that Franklin has at its disposal that they can, and do, make the best liquid hide glue. There are sound chemical reasons that it should be most stable and indeed I have never had it deteriorate with refrigerator storage. Someone in tech service at Franklin told me they had kept a bottle for 10 years with no ill effects. Mine is now 4 years old.
I have tried all sorts of dovetail glue spreading tools. The arrangement shown is what I now use. I pick up a dab of glue on the end of the square spatula and spread it across the wood surface. I apply a thin layer of glue to both mating surfaces.
The gluing order is as follows. Apply glue to both ends of a drawer side. Apply glue to the mating parts of the front and back. With this side flat on the bench, with its inside facing up, slide the drawer’s front and back pins into the side’s tails and tap home with mallet and block. Wipe off any glue that is squeezed out. (I use a finger and pants, or preferably finger and a paper towel). Apply glue to other end of drawer’s front and back and each end of remaining side. Slide together and tap home. Becoming confused with what goes where is not to be recommended at this step. I have labels on all the joints so I know what goes where, at a glance.
PIC 2 clamp the joint closed
The nature of hide glue and PV glue is that it has daunting impact strength when partially cured, but little shear strength. It is common that the dovetail joints will not tightly snug up when tapped, or bashed, together. Snugging is accomplished with the clamp as show in the picture. Clamp-shear accomplishes what mallet-impact doesn’t. (This trick works on all sliding joinery) It is satisfying to see that last tiny gap close as the clamp is tightened. I simply go around all the joints with a single clamp. Once pulled together they do no spring back if the joint was properly cut and free of “burrs” to begin with.
PIC 3
The next step will be controversial. Consider it, for it has merit. While on the bench I rack the drawer as needed to get it approximately square ( it usually comes together square anyway) Then I shove the drawer into its opening. I have stiff plastic pieces salvaged from the ubiquitous bubble wrap we all hate. They get wedged into each side of the drawer front opening as shown.
Pic 4
On the back of the drawer I drive wedges to hold the drawer centered in its opening. I might mention here that the step where any glue that is squeezed out is wiped away is a critical step. That said, I have glued dozens of drawers this way with none getting glued into the opening.
At this point check that the drawer is flush with the front and centered. This approach observed in the (dare I say it again) Headley shop ensures the drawer perfectly fits the opening, even if the opening is not perfect. And, the drawers are out of the way while the joints are curing.
PIC 5 Fitting
When the glue is thoroughly cured the drawer is final fit. Drawer fitting is an art. Drawers do no change in length with climate. Heights do. If the drawer is too narrow for the opening it will rack and bind when closing. If too tall it will swell and stick (fatal flaw) when humid. My fitting standard is to be able to close the drawer with one finger pushing on a corner of the drawer’s front. If it racks too much this test will fail and there is no fixing the deficiency. At midrange humidity I strive for a 0.032” gap at the drawer top and total 0.032” gap at the sides. (Recall this precise measurement is derived from the feeler gauge size I happen to have.) It is handy just running the feeler gauge around the gaps to check them. This approximate 1/32” total lateral gap on a drawer is what I see on fine antiques that have survived for centuries.
These pieces are staying in the family. If they get bindy at high humidity I can fix the problem, so I err on too tight to lessen racking and drooping deficiencies. Before delivery the piece is conditioned in some high humidity location and often some final adjustment to height is made. A height gap of 0.032” is too small for a large drawer made at lower humidity, if the drawer will ever see high humidity.
Contrary to some builders I do not diddle with the drawer front to achieve a gap at the drawer front bottom. Personally, I do not like the looks of a drawer front seemingly floating above the divider.
Not mentioned till now, the dovetails were cut so the sides would stand a few shavings proud of the fitted front after gluing the drawer. With the drawer held as shown in the picture the side is planed so the side is flush with the front and back dovetail pins and one shaving is taken off the pin ends to brighten them up. It is essential to chamfer the drawer’s back pins or they will chip out during this operation. I cannot overemphasize the joy of worry-free, tear-out planing that the cap iron effect has enabled in this step. I don’t care what way the grain is running.
To keep the back from potentially dragging on the divider above that may drooped over time the top edge of the back is spoke shaved slightly concave, (yet another Headly shop tip).
In summary, making a well fit drawer is a complex high precision task. It takes me a day to do one drawer from start to fitted finish. Alan Batty worked in an English factory making dovetail drawers (oak sides and mahogany fronts) and his daily quota was 6 drawers per day!
Re: Samantha's dresser 12- drawer assembly and fitting
Glue Time?
Looking good Bill. What is the typical working time with that hide glue?
Thanks
T.
There are two times....
Franklin explains that a glue has two times. The open time is the time the joint can remain open to the air and not surface dry to where bonding will be degraded. This time depends on temperature and humidity. The second time is the time (don't remember what they call this time) that a joint can be "adjusted" after assembly. I have spent 20 minutes on a complex dovetailed case assembly without problems, that is to say I could still coax joints into submission with clamp pressure, moderate humidity and temperature . Franklin claims that the liquid hide is longest of these times, but the differences are not huge. Not a factor of 2 or anything like that.
The best I can say is that the liquid hide is not at all grabby when sliding a sliding type joint together.
