OT Cutting Slate
OT Cutting Slate
OT Cutting Slate
William Duffield
I need to cut several slate paving stones in two lengthwise. They're random sizes, about an inch thick, about a foot wide and as much as two feet long. The cuts need to be relatively straight, but don't need to be smooth, since the cut edges won't be visible. What's the most efficient way to do this? I would prefer not to have to rent a wet saw.
Re: OT Cutting Slate
Re: OT Cutting Slate Options
William Duffield
More info, on potential options:
I could take the slate to a friend who is a mason and pay him to cut them for me, but I would be at the mercy of his schedule.
I have a Makita 5" angle grinder with a diamond saw blade, and another 4-1/2" grinder with abrasive cut off wheels.
John McGaw
A diamond blade in an angle grinder or the equivalent in a circular saw would probably do the job although you would have to go very slow to prevent overheating; making the cut in small increments will help too. It will be messy and dusty and unpleasant but certainly doable. The strength and hardness of slate can vary a bit from what I've read so the amount of abuse your specimens will withstand will need to be judged carefully. I've gone the circular saw route and cut a number of thick concrete pavers with good success.
If all of this sounds like a total PITA there is always the chance that you could mark the cuts and find a local stone/masonry contractor who will run the material through their wet saw for a small fee.
William Duffield
I have the disadvantage of starting with some pretty hard slate, specifically Buckingham®.
http://www.bvslate.com/
Ralph Lipeles
Borrow or rent a tile cutting saw. It uses a diamond blade and is wet wheel. it worked great for me on 1" slate.
Ralph Lipeles
Keith Newton
If you have a slightly dull carbide blade, preferably low hook, maybe triple chip, it wouldn't be anything lost to give it a try.
Buy a Hardy blade for your circular saw, surely would do it.
William Duffield
The trick there will be finding an 8-1/4" HardieBlade with a 30 mm arbor. I don't have a lot of choice in circular saws. :)
I've cut them dry with a circ and wet with a tile saw (with mask, face shield, and a small prayer that the abrasive dust doesn't wax the commutator, brushes, and bearings on the circ).
Wet tile saw is much preferred. Home Depot rental is worth the price. At 2', be sure to support the pieces as they exit the saw DAMHIKT
Gary Bindel
I've cut them using an angle grinder with a diamond blade. I set the hose on it with about a 1/8" stream to cool and keep the dust down.
I have cut more than I care to remember, about every way you can cut it. A good big wet saw is the best, but the diamond blade and abrasive blade will work too. Messy is the code word for this. More black dust than you can imagine. Wear Eye protection and a dust mask. To support it, you can lay it on a pile of sand and saw through it. Easier is to saw it from both sides, scoring it about a third of the way through and then break it. Blow out your was when finished. Use a borrowed saw, borrowed from someone you don't like.
PS, mine was Buckingham also. I actually made a slate cutter for thin slate. Worked sort of like a paper cutter, but not on slate that thick.
William Duffield
Thanks, Mark, especially for the outfeed warning.
As I implied in my reply to Keith, my circular saw is way too expensive to endanger it with a lot of rock dust. While it is well engineered, Im not going to take any chances.
