OT Stainless Steel sink Questions
Every Stainless Steel kitchen sink I have ever seen mounts with clips from below. There are "tracks" on them that form a sort of dovetail and you slide the screws into the tracts and then have clips that lever onto the underside of the counter top.
The sink I found in the house I just bought does not have the tracks. It has stainless steel folded under that has slots in it. It was just sitting there, loosely held in place by the plumbing. I am thinking the previous owner removed the tracks. Anyone know how to mount the sink without the tracks?
Re: OT Stainless Steel sink Questions
John McGaw
When I replaced my busted cast iron sink (a portion of the glaze just 'exploded' one day) with a stainless one I had the problem that, although the sink had tracks, the brackets wouldn't work on the super-thick tile countertop I had built years ago. I just put down a nice bead of silicone caulk and bedded the sink in that. It isn't going anywhere. I'm sure of this because that is how the cast iron sink was installed and it took brute force and a hydraulic jack and an hour of cutting at the caulk to loosen it.
Oops?
John, I think Barry's dealing with an under-mount unit. Caulk will secure a top-mounted sink, but won't support an under-mount.
Clips
Go to a real plumbing supply house (take a pic the sink's mounting rim) and get new clips.
Re: Oops?
John McGaw
Don't think so. The way the situation was described "...clips that lever onto the underside of the counter top." and "It was just sitting there, loosely held in place by the plumbing." sounds to me that this is a traditional top-mount. Could be wrong, I often am, but in this case it seems less likely.
silicone
Just glue it in place
Re: Or 3M 5200 if you...
TomD
have any reason to want to use the sink as a handle on the universe. There is some chance 5200 would under mount a sink.
I think it used to have tracks and clips
I am assuming they removed the tracks. It is definitely not an under mount sink. Its got the rolled down edges that usually come with a top mount. this was a thick home made counter top with floor tile on it.
I will look at the idea of gluing it with silicone. I am afraid the edges have a slight arch in them and the clips would have pulled it down to the top. This is a low budget house and I don't want to spend for a new sink if I don't have to. It has become a game to see if I can turn it around quickly and cheaply and still do a good job.
OK, My Oops
Top Mount.
Silicone bead should hold it
William Duffield
5200 is the stuff I would recommend as well. I use it for mounting centerboard trunks to sailboat hulls, reattaching surf sandal straps to soles, reattaching hiking boot soles to the boots, and other high stress applications. What would you use for cleanup if it squeezes out around the edges?
This is one of life's little coincidences. About fifteen years ago I built some garden bridges for a friend of mine. I used 3M 5200 to laminate the arches out of treated lumber. One for them was about six feet wide and spanned sixteen feet. I was sure it was strong enough for pedestrian traffic, but was sort of surprised when he drove his tractor across it.
I had a tube or two of the glue left over. Wonder if I can find it and if it is still good?
TomD
There is probably some solvent that would work, but one could just drop the sink over a mask, and pre-cut it with a razor, that way on can just peel off the mess. Or use a razorblade.
John Cotten
Pick up a used sink. I see them all the time at second hand/good will/ flea markets and have both them for $10 to $20 bucks without the faucets. Having mounted dozens of stainless sinks, I have never seen one you could take the tracks off of without cutting them off. They are usually spot welded to the sink. Shouldn't be too hard to locate a new one and not waste the time trying to silicone one down.
