Ram type radial drill press
Pete
I just got a Delta Rockwell 15-120 radial drill press and have some "pressing questions'.
I had to take it apart to get it home and before I put it together I would like to clean and lube the moving parts.
What should I use to lube the column and the jackscrew that makes it go up and down?
One of the bearings in the cradle was broken (the outer race was broken in two) so I am going to replace all 8 while I have it apart. The remaining seven bearings appear to be dry. Does anyone know the procedure to adjust them in order to take out the play and to keep the arm parallel to the table? Should I lube the ways on the arm or should they stay dry?
