Steam-bent White Oak Coil Spring *LINK*
Keith Newton
Some time back, Ben Jackson my assistant and I were somewhat bored by the kind of jobs coming our way, so we decided to plan on working late every Wednesday night on fun or challenging projects.
Many years ago, I had a book on steam bending, which had a photo in it of a spring like this that I was really intrigued by, and always wanted to see if I could duplicate it. The book didn't give any details explaining how it was done, or at least the finer points, so it was rewarding to manage to pull it off.
Anytime there is a discussion about steam bending, there will usually be some who argue that the unpredictable spring-back will be a game killer. But that may be an indication of their not having a full grasp of all the possibilities. I was actually hoping for more than I got for my intended use of this part. But that is OK, because it was the first time Ben had been in on steaming, and we both learned a lot in the process, which just inspires taking another step up the ladder.
Here is a link to some pics. I also included some shots of the rings that we finished last week. They aren't totally finished, and there are about 20 more in the works, just partially through the process.
I hope you will try to view these full screen, so you can see the detail better. K
https://www.flickr.com/photos/7391658@N03/sets/72157644095226123/
Re: Steam-bent White Oak Coil Spring *LINK*
Cool
My dad made a latchset for the door into the garage in his house years ago that included a steam-bent flat spring (along with a wood rack-and-pinion bolt). It lasted 50 years before the gears stripped, but the spring was still ready to do its job.
pretty impressive!
hennebury
That's really quite incredible.
Nice job and a nice piece of wood that the spring is sitting on.
I have never done any steam bending, but it looks interesting.
Larry Barrett
Pretty neat, Keith. Does the thickness of the white oak increase gradually? It looks like it does in the photos. Was the oak rived?
Thanks Mark and Larry
Keith Newton
That was some Redwood burl veneer which we had found down in my veneer drawers, and pulled out to see how it might work combined with another wood for the rings.
Larry, yes that was a long slinder tapper to begin with. I just sawed it off the edge of some air dried oak, and was just guessing at what might be the minimum bending radius from the beginning to the end. I had another 18" of length on my blank, which I should have been able to bend to that radius, but I didn't have any way to let off my end stop, so it buckled away from my strap, putting an end to the wrap.
We learned a few things, and both have some ideas we want to try.
Don Orr
That is some serious bending! Very impressive.
I also like the rings-smart to use branch sections for continuous grain all the way around for strength. At least that's what it looks like to me. Nice job all around.
Keith Newton
No Don, the rings are veneers wound up tight and glued, then saturated with epoxy. There is no short, or end-grain.
An interesting little tidbit,
Keith Newton
Above I mentioned the issue of spring-back or forward.
Yesterday, it had sprung forward 120º, then I thought I would fume it with ammonia. This dampened it a little, but now on day 2 it has wound 270º tighter than when it set. This would be due to cross-grain shrinkage as it dries. Coefficient?
Could you share a little about the process?
Stephen
I'd love to see a photo of the jig you used to hold it while bending the spiral. Thanks! and Great Work!
Not really
I've seen multiple versions of a humidity gauge made from two thin pieces of oak or similar wood glued cross-grain; as the wood expands/contracts across its width, it pulls/pushes the other piece.
I had thought about that, and
Keith Newton
Just in time to go in my Solar kiln when I get it finished. Although I would imagine it would need to be thinner to make it more sensitive, faster.
I was wondering if there was enough interest.
Keith Newton
Since there were about 100 views before the first comment, then another before you. I think at this time I'll leave it as a brain teaser.
We have some other ideas that we want to try which we need to play with to see if they work, then try to incorporate that into a functional piece.
I am picturing....
..... a dial fastened to the spring and this affair mounted on something like a clock calibrated in %RH. Even if it didn't work will it would be so cool everyone would want one.
Re: I am picturing....
The projects I've seen involved using the wood assembly as a needle, with an arc-shaped scale on the backing board. Calibration, of course, requires another humidity tester.
Pedestrian application of the principal......
This coil spring invites a more creative approach to the read-out, something as novel as the spring itself. If one can settle for ordinary a humidity gauge from LV will do.
Maybe the next, Sassafras destroyed this one. *LINK*
Keith Newton
I guess I left it too near the edge of the desk where she could snatch it, and she did, then chewed it up, destroying the two outer most coils.
Ha, have you ever seen a toofless golden retriever? Right now, I'm thinking she might look better that way.
Maybe I can still salvage something out of what is left though, I'll probably want to mount it high on a wall somewhere.
I posted another shot of it on the flickr site. Here is how it looks now. Aarg!
https://www.flickr.com/photos/7391658@N03/13942701355/in/set-72157644095226123
Don Orr
Even better-thanks for clearing that up. Nice work!
