ammonia
BradKansas
Does anyone know where in Kansas City or Topeka I can buy 29.4% Aqueous Ammonia for fuming white oak. My supply has weakened. Blue print companies no longer use it.
Thank,
Brad
ammonia
BradKansas
Thank,
Brad
Re: ammonia
John Veerkamp
In KC try Brookside Scientific. Located on 63Rd just west of Brookside Blvd.
Re: ammonia
mdclor
Brad, you can use weaker ammonia, it just has to sit in the tent longer. I have used household ammonia successfully. FWIW
Re: ammonia
BradKansas
Thanks John,
He can locally order different amounts and strengths and have it in the shop in a couple days.
Brad
Re: ammonia
BradKansas
Hi MD...
I'm the impatient type!
Brad
Another option?
Jason Roehl in Lafayette, IN
A disclaimer first. I have never fumed any woodworking with ammonia.
However, somewhere in the deep, spider-webbed recesses of my dusty, rusty mind, I recall from my high school and college chemistry classes that some of the ways in general to speed up a chemical reaction (aside from increasing the concentration) are to add heat or agitation (or both).
Jason
So, are you suggesting...
...that Brad put his piece of furniture in the dryer with a pan of ammonia and set it on "spin?"
Re: Another option?
Bradkansas
If fuming, how would agitation benefit? Perhaps the introduction of a light bulb in the fuming tent would help. However, if using 26% percent aqueous solution, darkening can occur in a manner of minutes, if not seconds. I do have some older ammonia which has weakened and takes forever to achieve the desired effect. Perhaps a light bulb would speed things up a bit. Thanks for the idea.
Brad
Re: So, are you suggesting...
Bradkansas
Bill,
It's 0020 here and your comment made me laugh loudly. If I woke my sweetie, your in big trouble.
Brad
Re: ammonia
Bradkansas
John,
Are you kin of Ely?
Brad
Re: Another option?
Well, I don't know how an aqueous solution of ammonia would evaporate, but I would guess that as ammonia molecules come off the liquid surface in the open container there would be a slightly lower concentration near the surface, and agitation would keep the concentration consistent. But, maybe the effect is so slight and diffusion quick enough that it wouldn't matter. I don't know, just thinking out loud here. Perhaps the better place to affect agitation would be to figure out a way to circulate the fumes in the chamber.
Jason
"stirring" unnecessary, irrelevant
There are two reasons to stir and neither are relevant to this application. If the chemical at the surface is being depleted by rapid or instantaneous reaction at the surface the rate of reaction, in this case coloring, would depend on how fast one could get stuff to this surface. Stuff can get there by diffusion of molecules of stuff through the space or by stirring (what is called "bulk transport"). Stirring will help get stuff to a surface when diffusion is slow.
In this case there will be a huge concentration of ammonia in the tent and the color forming reaction is not nearly instantaneous. Hence, the wood surface will never be depleted of ammonia. Furthermore, ammonia diffusion is fast. It moves through air about a foot per minute so it can get to the wood without the need for stirring.
This diffusion rate can be measured in an experiment that will amaze your children. You will need a clear tube about 12 to 18" long, plastic or glass, a bit of cotton, ammonia and hydrochloric acid (muriatic acid). Put a drop of acid on one piece of cotton, a drop of ammonia on another. Plug opposite ends of the tube with the cotton ball wet with ammonia and acid respectively. Start the clock. In a minute or two a white ring will form where the hydrochloric acid vapors meet the ammonia vapors. The ring is ammonium chloride formed by the reaction of ammonia with hydrochloric acid vapor. You will note that the ring forms closer to the acid end because ammonia is a smaller molecule than hydrochloric acid and it therefore diffuses faster. (the diffusion rate is proportional to the square root of the molecular weight)
It makes a good science project to explore the various variables one can think of, should your kids need a science experiment some year.
Re: ammonia
John Veerkamp
My Nephew.
