Building a Pedestal Table
Alan Young
I've been working on several projects in the last few weeks and haven't been taking the time to photograph the fabrication processes. But I did take a bit of time to turn my sketchup renderings into a bit of a construction story. Here is the Pedestal Table I've been working on-Construction is complete-just need another round or two sanding and then the finish. The table is made from Cherry.
The pedestal is made from 14 staves each joined to its neighbor with a spline.
The 14 staves required a beveled cut of 12.85 degrees. I ripped and cut each of these on the table saw. Then cut out the profile on the band saw. No lathe work was done at all. I glued the pieces together using Titebond Liquid Hide glue-I really like this glue and it is probably my most often used glue. The open time here was the main factor.
After the pedestal was glued and sanded I routed a recess in the top and bottom:
Then I cut a 3/4" piece of plywood and glued/screwed it into each end and Drilled a hole through the center of each plywood piece to receive a 1/2-13 threaded rod.
The pedestal has a 3/4 inch cherry "plate" that is then screwed into the top of the pedestal with a matching 1/2 inch hole
and the base is comprised of two 1.75" thick pieces-
The bottom piece has a routed out recess so I can tighten a nut on the threaded rod. There is a similar recess in the underside of the table top-allowing the upper nut to hide "inside" the top.
The top is then attached to the 3/4 mating plate with screws from underneath-It is not glued. Here now are fabrication pictures than I have managed to take of the piece:
The pedestal before routing the recesses.
The upper mating plate-bolted and screwed to the pedestal top.
A side view of the lower assembly:
The center of the very bottom with a routed recess to allow space for the nut and washers
The underside of the top has a similar routed recess so it can straddle the nut at the top of the assembly.
Here is the table all assembled: Thanks for looking-Alan
