car head lamp question
It must have been the first time I have driven my 2 yr old Ford Escape at night on a country, hilly road. It was terrifying.
The head lamps illuminate in a horizontal slit with almost no dispersion of light above or below a narrow horizontal beam of illumination. Think driving with elliptical spotlights. If I was going up a hill I was illuminated 150' or less ahead of the vehicle(depending on steepness of hill) and it was black above this point. Ditto for going down hill. Not what one wants on a curvy hilly road with deer waiting to jump out or sharp curves looming ahead.
Question? can I fix this problem by replacing head lamps? If so how do I ensure I get lamps that illuminate in the vertical as well as horizontal direction?.
Re: car head lamp question
Henry Higginbotham
The easy answer: Trade it in for a 1953 Chevy. :D
Failing that, you might be able to re-aim them to your satisfaction. My '02 BMW used to have the same problem. I aimed them a bit higher and can now finally see adequately at night. That was a few years ago, and so far no one's flashed their lights at me.
TomD
I don't know much about what is available in lamps these days, I don't seem to have to replace them. Before these days, that used to be fairly common. And at one time re-aiming them was a pretty common task also. I used to aim than at the garage door. I am puzzled by bill's predicament, because raising a slot will leave you with uncovered areas. I drove my parents car on a winding road, and it was similarly blind. They took it in and had it serviced and it was ok again. But in that case it wasn't a slot, it was more or less as though when the high beams were turned on, the lights were still on low. So the focal centers were on the road, not parallel to it and reaching out. They had them raised and all was good. But even when they are low, there is an area of weaker light reaching out all around.
HID Headlamps
Dustmaker Mike
If you are talking about a new style Escape you might have HID head lamps. If so you don't want to see the cost of replacing them. The way I get around this problem is to use the driving lights at the same time.
Keith Newton
Bill, I'm wondering if you might shoot one higher than the other to overcome this.
Jerry Roberts
Bill, my new 2013 Honda Odessey has headlights the same as you describe. First time I drove it at night it was really odd. Don't know if there is any fix or not but I don't like it either. Every time I hit a bump the light dividing line goes up and down. Jeez.
Two Words: Fog Lights
Lee Schierer in McKean, PA
Get halogen fog lights installed on your Escape. We had the factory ones on our Mazda Tribute and had no problems seeing at night in hilly country.
Leon
Lee had the best answer
Howard in Toronto
A vehicle's headlight's throw is mostly influenced by the reflector pattern (the silver background) in a light's "pod."
If you find that it's not a great throw or it's kind of dim, you're out of luck.
So Lee has the best and most practical answer - get fogs installed to illuminate the road in front of the vehicle and a touch further out too.
Howard
Two thoughts.....
cataract surgery and new glasses.... :) Or maybe you could just put the eyeglass lenses right in front of the headlights and refocus them.
My friend's wife's car needed a new headlight bulb. The bulb was $82. Say what????
