20mm saw arbor, adapter, sources
TomD
I have an Inca 10 inch, and just sold a second to someone else. I was wondering whether anyone has tried adaptors in 1" bore saw, like these:
http://www.ebay.com/itm/1-x-20-mm-Re...-/140887027243
There could be some risk of their coming out, as If the discs in the nut stack are concave. Maybe epoxy would work.
For 8"-10", and metric equivalents, who supplies the blades drilled 20mm. I am just boring them on my lathe as I need them, but I imagine I will get questions about this from time to time. Forrest makes a blade with 20mm bore, but the hassle with the old Inca 10" is that it really needs two blade sizes to be workable. So the blades start to add up. that could be 6 blades for starters, could be worth a lot more than the saw, and I don't see the 8 or 9 inch options one might need.
Re: 20mm saw arbor, adapter, sources
Paul in NJ
Forrest will bore any of their blades to 20mm for a nominal charge, I think it was $8.00 US last time I bought a blade. I don't know of a source of 1" to 20mm bushings.
Paul Dzioba
Lee Schierer in McKean, PA
Loctite makes an retaining compound adhesive specifically for mounting sleeves into bores.
Lee
Rick L
Arbor bushings
Rick L
Been using arbor bushings for 40 years. Freud, Amana, etc make them. Typically we bore out the dado sets to 1" and with the bushing we can use them on 5/8" arbors. There's serrations on the outer perimeter to keep them in place. No need for epoxy or loctite. You can get 30 mm, 25 mm, 20 mm, 1" OD's with various ID's. Your saw sharpening shop should have access to them. If not get a new sharpening shop.
Re: Arbor bushings
TomD
Thanks that gives me an answer, I think you can probably find someone who will bore to 1", if not 20, though that is a size for tile saws or something. And the bushings are easy, so that would be a good response if I get any questions. I can't do it for 8 bucks, so that leaves me happy on the sidelines.
Rick L
Re: Saw Arbor Bushings Link *LINK*
Rick L
I can barely understand what you said. I am surprised so few people know about saw bushings. It's even more amusing how folks who know nothing of saw bushings invent and speculate on the subject. The internet is so amusing...
Amana Saw Bushings
TomD
Yeah I can't seem to fathom what you are saying either. For instance there was a link to bushings in the original post. I think part of the problem is you get general purpose know it alls who's info may not translate to specific cases. Whatever may exist out there probably wasn't put in place for people who buy Inca saws or to suit the lifestyles of those who buy them. But it certainly helps to at least have a plausible option, for which I was duly thankful.
