I don't get it.
Jason Roehl in Lafayette, IN
There are two reasons I don't use boom lifts more often: access and cost. Otherwise, they're one of the safest ways to get a lot of work done up high in my experience. I had an 80' boom lift up to about 65-70', at least 40' above the roof of the building I was working on, on a somewhat windy day (10-20 MPH winds). It swayed, but I wasn't at all concerned it would go over. I would have taken it all the way up, but I didn't realize the boom had to be near or fully vertical before the bottom section would extend. (One of these: http://www.whellock.com/product_data/jlg_800a/image.jpg ) These things are HEAVY--the 800A is over 34,000 lbs, a 60' boom is about 24,000 lbs, and a lot of that weight is in the base. They also typically have tilt alarms and safeties built in. They're pretty safe, especially if you're operating a ways below the capability limits.
Anyway, by access, I mean that often there is no way to get a boom lift around a house or building because of landscaping, soft ground, tight clearance to other buildings, etc. If those conditions aren't present, then cost is the deciding factor. A typical delivery/pick-up fee is about $300-400 around here, plus the daily/weekly/monthly rental. On small jobs, it's probably not worth it, but if it's a large job with lots of high work or difficult-to-reach features, then it's a no-brainer. Setting up scaffolding is time-consuming and physically demanding.
Jason
