200+ woodworking book reviews
OT: How to keep paint on PVC pipe
Henry Higginbotham
I play golf at the local muni in a town with insufficient budget to do much to a golf course beyond keeping the grass cut and the lights on.
We've formed a volunteer group to make what improvements we can with what money we can raise. Among the projects in new tee signage to replace the rotting 20-30 year-old treated wood structures.
The current (cheap and quick) plan is to make a two-post sign structure from 1½" Sch. 40 PVC. The prototype (which looks somewhat better than it sounds) was primed with something pretending to be plastic primer, then sprayed with your standard Rustoleum dark green from Lowe's.
The paint comes off the prototype if you bump it lightly or even give it a dirty look. Anyone know if it's possible for us to paint this stuff in a manner that's durable, and without breaking the bank?
Re: OT: How to keep paint on PVC pipe
Dick Coers
Was it a plastic primer made for automotive use? Get some real paint from the auto parts store, not something from a big box store.
Buy paint made for plastic
Grant in Iowa
Choose a paint made for plastic such as Krylon's Fusion for plastic.
I'm the Geek . . .
steve mackay
. . . who wanted his PVC dust collection pipes "safety yellow". I just scuffed all of it with 220 grit and used Krylon. 15 years and it's still yellow. No peeling, no chips.
Re: I'm the Geek . . .
I agree with both of the above. Scuff sand the surface to get the shine off and paint with "plastic" paint like the Fusion.
10 years good . . .
steve mackay
PVC "property line marker". Scuffed and Krylon. 10 years in the El Paso sun.
Joe Burke
I gotta agree. Scuff it or sand the dickens out it. It's not gonna be inspected close up is it. Maybe clean it with some mineral spirits or the like to make sure it's degreased? Pick the right paint ... and I admit I didn't even know you could get paint for plastic ... and have at it.
I did this to PVC that got beach exposure and it held on pretty well. And that was just normal old spray paint.
An additional thought.....
Early in the days of plastic pipe the building code required that PVC pipe be painted where it was exposed to sun. (Like where it sticks through the roof) People thought it was for cosmetics to make the vent pipes look better on the roof. Actually it was to sun block or keep the UV light off the pipes. Being white they were subject to UV damage all the way through. They could get brittle and break.
For your next project you might switch to ABS pipe. Its black and not as subject to UV damage.
Try This
Bob Lang
Way back when I worked in the scenery department of an aquatic theme park. Our solution was to "prime" plastic with PVC primer, the purple stuff you use when you glue it together. Swab on a thin coat and let it dry. That accomplishes the same thing as scuff sanding without as much time or effort.
One of the issues I see with your inexpensive solution is longevity. My bet is you'll be replacing the post in a few years. An upgrade to schedule 80 might survive a couple of seasons longer than sched. 40.
Bob Lang
Thanks . . . and some updates and comments
Henry Higginbotham
Some good suggestions here, which we will try if we hit a snag with our new "Plan A," which is to have them painted by one of our regular golfers who runs an autobody shop. He supposedly knows how to make it stick.
I had thought about some sort of etching de-slicker stuff but didn't know what might work. I'd also thought briefly about hand sanding, but worked diligently to purge that idea from memory. :)
As for Schedule 80 vs 40: We are considering this a temporary upgrade, pending selling sponsorships for each tee and then upgrading to (probably) treated wood. And Sch 40 was available at a good-buddy deal, whereas 80 wasn't.
Thanks again for the suggestions.
TomD
Two things:
1) Whatever you do run a test.
2) Two ways to get stuff to stick other than using commercial products, are 1) to light flame it. Just pass a flame over it enough to cause the shinny surface to haze. Probably not practical on your scale, but a great tip for many other applications. When the tube hazes, it has oxide on it, and many paints will stick to the oxide, and glues also.
O use cement on the surface that will band, and you glue or paint will bond to the cement. Again, not as easy as spraying with a purpose built product.
walta
No paint on PVC will ever stand up to weekly run in with a weed eater.
This fence post is strongest cheapest option.
http://www.homedepot.com/p/Unbranded-4-ft-Lite-Duty-U-Post-14-Gauge-Steel-with-Green-Powder-Coat-Finish-901154HD/204331911
2 inch conduit no need for paint.
http://www.homedepot.com/p/Allied-Tube-Conduit-1-1-4-in-x-10-ft-Electric-Metallic-Tube-Conduit-101576/100400410
Re: OT: Agree flame is often used
When I was working a few years ago our plant did a lot of printing on plastic. As part of my research on this process, I visited a Lionel model train factory. I learned of the flame process there. Plastic when molded has a slick resin rich surface which will not allow paint or inks to adhere well, sometimes mold release is also present. So a quick incursion into a flame removes this resin and allows excellent adhesion. I did this on automotive parts, time in the flame was only a fraction of a second. We had zero problems with adhesion after that and passed all GM requirements. No doubt sanding, or possibly even application of "primer" will eliminate the problem but may be simpler to just run a propane torch over the surface at a walking speed prior to painting with a paint formulated for plastic.
