Shop man door.
Shop man door.
Shop man door.
James Heaston
I'm curious as to why doors open in to a building instead of out. I need to replace my door & in the case of thief deterrent believe it would be better if the door opened out. A target er I mean a thief could only grab the knob to force open the door provided you didn't use loose pin hinges.
On another note, I'm thinking of building it out of CCA plywood sheets laminated together w/ inlaid metal inside for reinforcement & replacing the door posts w/ black locust. If they don't look under the welcome mat for the key they'd break a sweat even if they have a FUBAR.
Re: Shop man door.
as a practical matter....
If you ever approach an entry door with hands laden with stuff it will become apparent why opening in is more handy than opening out. Also in a windy location the wind won't catch it. I have out-opening barn doors and they can be a challenge when it is windy.
Commercial doors do open out for emergency exit.
The bottom line is open what ever way works best for your application.
Re: Shop man door.
I think the hinge pins are the main reason
Yonak
..And the thresholds are designed for inward swing meaning, if you turn the door around, rain may leak under the door. Plus .. another small concern .. you couldn't have a storm door or separate screen door.
Re: Shop man door.
Re: Shop man door.
BrianMonumentCO
Another consideration strongly related to the hinge pins, at least door opening direction.
But not addressing their exterior vulnerability.
The issue is how much effort does it take to pull a door shut as opposed to pushing it shut.
If I was defending my house push a door shut is much easier than pulling it shut.
Re: Shop man door.
Re: as a practical matter....
clay foster
What if you are going out with an arm load of stuff?
Re: Shop man door.
never happens.....
Everyone knows that shops gain more than they loose. :)
(Actually, going out one is going from the confines of the room to somewhere more remote. Easy to preopen the door and close it by catching your toe on the door upon leaving. Coming in is usually from a remote location where it is less convenient to preopen the door. At least that is how things work for my door. )
Re: Shop man door.
Re: never happens..... *LINK*
clay foster
A lot of forum discussions remind me of this All In The Family episode. 8)
A sock and a sock
Re: Shop man door.
I was told
Gary Smyth
that residential doors opened in to allow entrance/exit when there was snow outside. There was always an "out" for a small number of people. Also a "in" opening door didn't force the person trying to enter off the step in front of the door. I called, and local fire personnel advised commercial doors open out to prevent masses in a establishment rushing a door in a panic and forcing it closed when many headed for the door at the same time. If you're going to the trouble of laminating a door why not consider a steel frame and frame it however you choose? I'd choose a in swing and the steel might make you feel more secure -- it might help insurance rates too.
Re: Shop man door.
Re:  I was told
I was taught that the reason residential doors swing inward is to allow you to put barrier across the inside to prevent entry.
You can buy hinges that have "Anti handling" pins. Some of them have set screws that are located so they can only be accessed when the door is open. They may also have "dimples" that create a tongue in one leaf that protrudes into a hole in the other leaf so that even if they get the pin out they still can't get the door out of the opening.
Many manufacturer's of steel doors make doors designed to open outward for storage sheds. You could look at one of those if they have one in stock at the borg or lumber yard.
Re: Shop man door.
James Heaston
Those were the days. :D
You're so right Clay. ;)
Re: Shop man door.
Re: Shop man door.
Matthew Robinette
I suppose if you wanted to make it more secure the installation of a steel raised panel pocket door would give the greatest barrier to unwanted intrusion. Just sayin
Re: Shop man door.
Re: Shop man door.
James Heaston
First off this is for my shop. It's obvious why residential doors open in. Once you got inside the automatic closers on the screen door would close it & so how are you going to get out. You'd have to call the fire dept & who knows if the insurance will pay for the house call. Of course you could put the screen door on the inside, but who wants a screen door hitting 'em in the backside while they're fighting the wind to close the door. >(
Another good point for the OOD (Out Opening Door); the hurried mass exit! Especially on burrito night at the Heaston's! :O
We're often concerned about the footprint of our machines. What about the footprint of the IOD (Inward Opening Door)? There's some valuable floor space I could use! Like Bill said, there seems to be more coming in then there is going out. In fact it's getting to the place in my shop that if you want to walk out you gotta back in. :\
A steel door on a wood shop? That is so wrong in so many ways! From what I've seen of them they're just tin plated MDF.
Dimpled hinges - I like that idea. :D
