Samantha's dresser- 12 dovetailing drawers
Dovetailing the drawers
The procedure I use is largely based on what I learned in the Mack Headley and Sons shop with some modification to accommodate the fact that I don’t do this operation very many times a year so I never get very efficient or skilled at it. I have no hesitation to employ useful “crutches”.
PIC1
The drawer front and back are fitted to the front opening with 0.032” total clearance everywhere along the top and side. Why 0.032”? Because that is the thickness of the feeler gauge I have and it seems to be just about right, or at least it has worked well in the past. Note: I am at this point final fitting the drawer front to the opening in the case, whatever size and shape this opening is. It is rarely perfectly 90 degrees. I may adjust the height in the final fitting after gluing but probably not the length.
PIC2
Step 2 is to nail the lumber for the two drawer sides together with two brads located diagonally on the drawer side. One brad head can be seen just below the clamp pad. I make most drawers 7/16” thick and I use poplar. This assembly is then cut to length and height to fit the drawer opening and case length. (Failure to account for the amount of drawer length that will be added by the half blind on the drawer front will lead to great annoyance when the finished drawer sticks out the back of the case.) ****It is essential that the ends of the drawers are perfectly 90 degrees to the sides. I use a shooting board to trim to perfection.
PIC3
The handy device shown in Picture 2 is used to lay out the dovetails. It ensures they are all the same size which makes them look attractive. Dovetail spacing may be off a bit and one will not notice. However, is the pins are different sizes it is more readily noticed, so I avoid this situation. It must be remembered that the drawer is to be cock beaded. The half pins at the drawer edges are made a bit larger to accommodate the removal of material for the cock bead.
I am not very good at sawing and a crutch helps at this point. I back up the piece being sawed with a stop to keep the saw from over sawing the back of the piece where I can’t see. This stop can be seen clamped to the drawer sides in Picture 2.
PIC 4
More crutches......I am not very good at marking either. To ensure the front and side are in the same plane I clamp them together on a flat surface with a piece of angle iron in the corner and then scribe the pin lines from the drawer side tails. Most people do this operation on the bench after aligning the two parts by eye and feel. I have on occasion gotten out of plane drawers with this approach so now I use the angle iron approach unless the drawer is deep. A deep drawer is easier to ensure alignment.
PIC5
I have a hard time seeing the scribe lines. I darken them by lightly drawing a very fine pencil line along the scribe line. As seen in the picture some of the scribe lines have been darkened this way, and others yet to be. Also shown in the picture is a backing board behind the thin drawer back. This assembly stiffens the thin drawer back and makes sawing it easier. Others have made dovetailing vices for this task which appear to be nice for the task. But it is something to make and store, for better or worse.
PIC6
I remove the most of the dovetail waste in “through dovetails” with the band saw. A coarse blade can be used like a power chisel to nibble right up to the scribe line. The pesky triangular piece that remains is removed with the saw shown.
PIC7
The half blind pins on the drawer front are marked and the bulk of this waste is removed with a router. The bit will not chatter (for some reason) if arcing cuts are made as shown in the picture. With good light the waste can be removed almost to the darkened scribe line. Some that use the router for waste removal do so with the router perched on the end of the board. I see nothing by disadvantages to this approach, but if there is someone that thinks it better we would like to hear their arguments for this way. The rest of the dovetail waste is chiseled away conventionally.
A diversion about over sawing the “half blind” pins. To be period correct to their area the Headley shop overs saws the length of the half blind pins. These saw kerfs become a prominent feature of the drawer. I think it looks awful and I don’t see that it makes waste removal quicker. If it will be covered by the cock bead I do slightly oversaw the top of the pin as shown in the picture below. Under sawing makes removal of another pesky triangular piece difficult. Perfect sawing to the scribe line would be ideal, if you are a perfect sawer.
PIC 8
A router that has good balance, an included light and a sharp bit is important. The solid carbide bits are a different material than the welded bits and they last many times longer.
PIC 9
Again there is a pesky triangular piece to be removed. I find it best to first deepen the scribe line with the chisel. The over sawed top of the pin makes alignment more certain.
PIC 10
Then the sides of the pins are pared. This is my favorite drawer building activity, I suppose because the result is usually favorable. I brace the chisel against my hip and thrust it into the pin waste. If the chisel is sharp it is most satisfying to shave off this waste. By orientating the chisel is the three axis all but a tiny whisker of the waste can be pared away with no need for a skew chisel. That last pesky whisker in the corner is just pried off with the chisel blade held on edge as it is in the picture.
PIC11
Not mentioned earlier, I strive to saw the pins so as to leave just a whisker of scribe line. As the pin waste is pared away the saw kerf is revealed as shown on the second pin in the picture. The top scribe line, if any remains, and remnants of the saw kerf provide a reliable paring target to yield a perfect sized pin, provided it was marked accurately.
PIC 12
When all the waste is pared away I check the result with a square to see that there are no high spots to interfere with the drawer side seating properly on the front and back drawer parts. Invariably I find some small high spot that must be removed for the drawer to come together perfectly.
I do a test fit before gluing. The drawer side must start onto the pins with no more than fist tapping/pounding. If it doesn’t, stop, and find out why it is not coming together. Bruised pins and split tails result from brute force at this stage of fitting. Use the presence or absence of a scribe line remains to search for tight pins. Once the pins start into the drawer sides a soft mallet can be used to finish seating. If there is resistance, stop. Get a steel hammer with a smooth face and tap each tail. Seized tails will ring while adequately fitted ones will sound dull. Pare as necessary to get a good fit. Undercutting the pins and /or tails a bit can sometimes fix a tight fit while preserving a crisp fit where the joint can be seen. Overworking a pin invariably results in a sloppy mate of pin to tail at the overworked junction (now how do I know that?). However, dovetails are so strong that even a sloppy fit will hold the drawer well for centuries and.
