Have a chance to pick up a Freud FT 2000 E plunge router fairly reasonably. Is this a good router? Does anyone have experience with it? How do you attach guide bushings to it? There seems to be a place in the base for some sort of insert, the insert is not with it. Can it be had? This one seems older, but lightly used. Any idea what you would pay for one?
My main router is an FT 2000. You can easily put inserts in the base. Freud makes a complete kit (FT 2020) that includes the insert you need. The insert did not come with the router. It is a brass set with
The Shop Fox insert looks similar, but may not be the correct dimension.
The guide bushings that come with it appear to to be the classic Porter Cable guides. Right? I have several set of them left from the router they stole.
I made my own base from 3/8" thick acrylic that accepts Porter Cable bushings. I wouldn't be surprised if Pat Warner sells a base that would work if you want to use P-C bushings and don't feel like rolling your own. Mine has been in a table for at least 15 years - being a home hobbyist it doesn't get a lot of use. I did replace the lower bearing with a sealed Fafnir. The original was shielded. I figured living upside down, that bearing had more crap falling on it than normal. I mounted a router raizer not long after I got it and so far so good.
I bought mine almost 15 years ago to sit permanently in my router table. Never any issue, and it's a very good router for that purpose. I think it is too big for handheld use. I have a Dewalt 621 for handheld plunge chores.
I think that the bushings are all pretty much the same size, but I only own the Freud set so I've never tried other brands. I like the router. It has plenty of power and the variable speed and soft start are nice. The only issue I've noticed is that the router can cock slightly on the plunge tubes. When raising the router in the table it will sometimes bind up. I try to set the bit so that it is too high when the router is out of the table for a bit change and then lower the bit to cutting height once the router is back upside down in the table.
If you have 1/4" shank bits, Freud makes a six finger collet for 1/4" bits that works much better than the 1/2" to 1/4" split bushing. You should be able to call Freud and get one through their service department. Make sure they provide a nut with the collet as getting the collet out of the nut is difficult.
Berry join the router work shop , it is for routers and how to use them and all about inserts ect, i have been a member for yrs now , lot's of info here is the link all you have to do is regester, http://www.routerforums.com/
This would be far from my only router, I have six I can think of and had one more, a big plunge router that got stolen. I have a chance to get this one cheap and was trying to decide. if it would be a worthy replacement for the one that disappeared in the night. I will check out the router workshop.
I've owned two FT2000s and really liked them because they're really basic and intuitive, unlike some of the other router brands out there, and they're a good value because they do everything you want a 3-hp plunge router to do for a lot less than some of the fancier brands. The FT2000 has plenty of power, a user-friendly plunge lock lever, and a basic turret-style depth stop. I did burn out the soft start switch on my first FT2000, so that may be a possible vulnerability, but I wouldn't let it influence my decision.
I had the PC template guide adapter and IIRC it was just a generic plate, easy to get. I gave the last router to my son a couple years ago so I can't check the plate recess diameter.
Right, that is how they come, but the adapter tends to slip on some router bits that are a little under size. You have to put a lot of torque on the adapter to get it to grip well. The six finger 1/4" collet grips much better and never slips.
