Urethane questions
Built a table out of QSWO. Client wants Satin Urethane, so I bought a quart of Minwax only to discover I had about a half can on the shelf of unknown age. It was very tightly sealed and appeared to be in perfect condition. No skim or scum. Stirred it as directed. Wiped the piece with Mineral spirits as directed to remove the dust. Applied a thin coat with a foam brush as directed. It took much longer to dry than expected. In fact, the top was still a bit sticky this morning after about eighteen hours. I left in my gara....er..Shop with the heater running.
So, the questions....Did I not wait for the Mineral Spirits to dry thoroughly enough?
Should I have not used the older urethane?
And, is Urethane urethane? I have some Varathane Floor finish and am considering using it to build the finish. I was going to use it altogether, but it is gloss and they want satin. Can I use it and put on a final coat of Minwax satin urethane? (Afraid I am mixing chemistry here.)
