drying lumber and end checks
PIC 1
An approximation of a tree is a bunch of soda straws glued together by lignin. Moisture is readily transported along the length of the tree as well as radially. As a result wood dries most rapidly from its ends, much less rapidly from the flat grain face and slowest from the quarter grain. When freshly sawed lumber begins to dry the ends can dry enough faster that the ends shrink faster than the bulk of the lumber and the ends check as illustrated in the picture. This end was dried for only 2 1/2 days at moderate temperature and it shows checking already.
Studies at VA Tech have shown that end coating lumber reduces the amount to checking due to rapid end drying. However, to be effective it must be done before checks develop. Clearly in the case illustrated after 2 1/2 days end coating would have been too long to wait. That said, I have never seen lumber or logs end coated in my area, no do I do it myself except when drying exceptionally thick lumber.
PIC 2
As illustrated in the second picture, there is another type of checking that end coating will not prevent. Some logs, and especially cherry, have stress in the center of the tree. The log end will stress crack soon after the cut is made. This crack will usually be a single crack across the pith.
