cleaning ceramic floor tiles
Bruce, a MN Galoot
A bit OT, maybe, but here goes. We have ceramic floor tiles at work, necessary because our mechanics, gas crew and linemen are always tracking in one nasty thing or another.
Lately, though, there seems to be a lot of asphalt trailings, what looks like little scuff marks that are tracked in from who knows where, but they are tar, not just scuff marks from rubber-soled shoes.
Mineral spirits with a scotch brite pad will easily clean the stuff, but will that also take off any sealer that's applied to the tiles as well?
Our cleaning lady wants to know so she can do the right thing.
Thanks.
Re: cleaning ceramic floor tiles
There should be no need to seal a well glazed tile. They are not porous. Toluene will work better than mineral spirits.
Bruce, a MN Galoot
thanks, Bill, I'll give that a try.
We use a floor machine... but
Grant in Iowa
Bruce,
I am the Director of Facilities at the National Czech & Slovak Museum & Library here in Cedar Rapids. Our main halls and restrooms are covered in 18"x18" ceramic white tile. We have our share of foot traffic you might say.
Because there is so much tile here, (~5000 square feet)we use a floor scrubber machine to do all but the corners and restrooms, with a hand mop taking care of the rest. The floor machine does a great job, but we have to augment with a green scotchbrite pad dampened and placed on a small push broom head at times in areas where scuffs or sticky spots occur. Works great, and not much effort required.
We don't put any sealer on the floor, as it only serves to lock in any dirt to the grout lines, so we find it best to go without. Our grout is the epoxy variety that supposedly never needs sealed. We clean the floor with a little vinegar in the water of the floor machine and sometimes some pine-sol for a fresh scent as needed.
FWIW,
Grant in Iowa
Re: We use a floor machine... but
Bruce, a MN Galoot
Turns out that your suggestion is just what the boss has decided to do. They're a small outfit and are hiring someone else to do the work. Apparently, our guys are doing something in the shop/truck bay that has this asphalt involved and so they will wait until that project is finished before tackling the work. Our company doesn't let me out of my room (municipal utility control room) ever so I can't go to inspect the source of the problem.
