Mounting sign on sign posts?
I will be mounting a sign over at the Playhouse.
The sign is a framed piece of MDO that is painted. The frame is 2 x 4s on "edge" around the piece of MDO. I've glue two layers of cut out mountain "ranges" onto the large rectangular piece.
I need to dig a couple of post holes (rah). I need to figure out a means of mounting the sign on the posts.
First thought - cleats on the front of the posts to "hold" it up on the post - and then a couple of bolts or timberlok screws through either the front 2 x 4s or the posts. I don't really want to "emphasize" the posts - so I'll be putting them behind the sign.
Other suggestions.
Re: Mounting sign on sign posts?
looks like a reasonable plane to me
I have mounted several signs for the neighborhood greenhouse. Don't set the posts until the cross pieces are on and secured, straight plumb etc. Once the posts and frame are rigid and oriented then fill post holes.
I don't know where/how the posts intersect the sign, nor whether the back of the posts and sign will be visible, but lag screws ought to do it. If the back of this arrangement isn't visible, you could just use some aluminum angle iron.
Is there more to this than I am seeing?
The back of the sign will be towards the building.
I just don't want the posts to be that noticeable.
John McGaw
The paint used for the posts can be selected to 'tone down' their visibility. Generally, darker will be less obtrusive as will flatter.
