Tea Box
Tony - Memphis
I posted a few weeks ago asking about rabbeting a veneered box. I am almost done with it now. I did some experimenting with scraps before I committed to a rabbeting technique. The waterfall bubinga is splintery and the cross banding was cutting cross grain. I buried a nice sharp CMT spiral bit into my router table fence and all went pretty well. I started each rabbet by backfeeding just a hair so I wouldn't get any blowout at the ends. That seemed to work pretty well.
This is before any finishing...
The sides are waterfall bubinga, the top is figured makore and satinwood. Those Brusso hinges from Lee Valley are VERY nice! The jars are from Hobby Lobby.
I used Better Bond glue for the sides/top veneer and liquid hide glue for all the other stuff. The inside is satinwood. I finished it before cutting and assembly. The box was built with no veneer on top, separated on the TS, then the top veneer panel was glued on. I used a vac bag for pressing. Rubber pond liner works well under the cauls to make up for the differences in thickness between the veneers, inlay, etc.
Top right out of the press..
After one or two coats...
