Is the grease on drawer slides silicon?
I was installing the full extension drawer slides on the table I am building and realized they are greasy. I sure I got some on the unfinished wood. (I wiped them off and tried to be careful, but I am betting some escaped.)
How do I tell if the grease will show up in the finish? And how do I remove it if I must?
Re: Is the grease on drawer slides silicon?
Tony - Memphis
Not sure, but I had the same concern. I cleaned with mineral spirits and had no issues.
Tony
John in NM
I always assumed so since it seemed to have no color at all, but I don't know really. Mineral spirits or lacquer thinner, maybe sand afterwards and repeat. Not much else you can do that I'm aware of.
Jason Roehl in Lafayette, IN
As the son of someone who worked their entire career for Dow Corning (makers of raw silicone), I have to point out that silicon (no e) is the element, and silicone (with the e on the end) is a polymer used in caulks, sealants, lubricants and the like.
That said, usually the solvent for a silicone product is acetone. Lacquer thinner often contains acetone, so it would probably work also to ensure there's no residue if you wipe off the surfaces to be finished with a paper towel generously dampened with the solvent.
I'd be surprised if it were a silicone product, but that's just a gut feeling.
Jason
Thanks, and Does silicone contain silicon?
Just wondering. This is some sort of nearly colorless grease sort of like Vaseline.
Most likely a Lithium based lube. Accuride states on their web site the lubricant used on their slides is a "Food Safe" lubricant. Most of the lubricants I have tested as an Engineer, that were so named were lithium based. As Jason has stated Silicone will be removed by Acetone or Lacquer Thinner. I would expect any "grease" could affect some stains and coatings. The above solvents will remove silicone, lithium based, petroleum bases, most synthetics, and almost all other greases, if I suspected contamination from ANY lubricant, I would clean the surface with one of those solvents and continue to finish without worry.
Nothing will remove any sort of grease from wood
Think about the situation. Solvent added to surface of wood with grease. Grease dissolves in solvent and becomes diluted. Solvent penetrates into the wood carrying grease with it. Some solvent and grease is removed by soaking up solvent with something absorbent. The rest diffuses ever deeper into the wood.
the only way to remove anything-grease, stains, etc- from something absorbent is to back flush the material with solvent into something else that is absorbent.
Silicone grease is expensive and unlikely to be used where a cheaper grease will do fine.
I once refinished some cabinet doors that had been waxed with a silicone containing wax. The doors were stripped with methylene chloride stripper. Enough silicone remained on the wood to fish-eye the finish. If it is this hard to remove traces of silicone from a varnished surface, consider the problem of removing it from an absorbent unfinished surface. The phrase "fat chance" comes to mind. BTW, wherever did this strange phrase get invented?
Howard Acheson
Can you see areas that are discolored from the grease?
You can also dampen a rag with mineral spirits and wipe a thin film on the wood. This should highlight areas that contain stains from the grease.
In general, it is difficult to impossible to remove grease from wood.
While you're pondering
Jason in OC
Why do "fat chance" and "slim chance" mean the same thing?
