Micro pipettes, I am happy!
TomD
One of my favourite things around the shop are micro pipettes. These are tiny plastic pipettes that are perfect for dispensing super glue, and other things. Being cheap, and in Canada, I have been using the same bag of 25 or 50 of these things, only on "spongeworthy" moments in my guitar building, for about 15 years! I occasionally manage to find these in different sizes and with fat tips, but never in the format LMII sells them in. What is so great about the LMII format? 3 things: 1) It dispenses micro droplets of super glue, that are very controlled, and allows infinite build/repair opportunities on complex projects, or cosmetic repairs; 2) the bulb has a small enough capacity that the glue does not harden overnight. One can get several days out of them, sometimes a week or more; 3) the tip is fine enough for those tiny repairs, but also fine enough that the glue does not dry due to the air hole. Sometimes I stick a pin in the end to reduce drying further, but often I don't bother. The correct hole is actually too small for a normal sewing pin to easily fit.
Apparently the trick for this style of tip has been out there a while, but I finally found it, and am really happy! So I am sharing it with those of you who may not already know.
The trick is to stretch the tips until they are the correct size for your use as described here:
http://www.frets.com/FretsPages/Luthier/TipsTricks/Pipette/pipette.html
Great site by the way.
I did my first one, using pliers, and got a corkscrewed tip that was not really stiff enough. I made the second by holding just ahead of the bulb with my weak hand, and holding the tip in the pliers, then pulling more slowly while watching the fat part retreat to the main part of the pipette as I stretched on the whole thing. I stopped pulling before the whole of the fat tip was gone, and I held on a second or two before letting go. I didn't let the fine tip snap back. Result, perfect tip. When done this way there is a reduction in two steps to the pipette, which I like.
Here is where I got my pipettes. Ideal for Canada due to the free shipping.
http://www.ebay.com/itm/281211132353?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Here is the original product, I guess the price is understandable if they are actually partly hand made:
http://www.lmii.com/products/finishing/adhesives/micro-pipettes-for-super-glue
While having much cheaper micro pipettes will allow me to use more of these, one of the great things about them is that they last and preserve glue well. So I will try not to waste too many of them.
Re: Micro pipettes, I am happy!
William Duffield
That's a great tip, Tom. When I saw it last night, I had to run right out to the shop to try it. It even works for dispensing liquid hide glue, if you keep it warm enough.
You also found a great deal on the pipettes. I paid about twice as much per unit (4¢ with shipping) even with a 500 quantity purchase. It's going to take me a long time to use up 500 of them.
I noticed that your ebay seller is out of stock.
TomD
Rats, He wasn't before I wrote that. I was going to order a few hundred more to last me out. It obviously doesn't take much to make me happy. I was a little miffed to see this tip goes back decades. I have been waiting for this tip for decades. I am also pretty patient.
William Duffield
If he doesn't restock, and you can't find them elsewhere cheaper, here is a "fallback" source, where I got mine:
http://www.amazon.com/dp/B00207CO7I/ref=pe_385040_30332190_TE_M3T1_ST1_dp_1
TomD
Thanks for that suggestion.
There are other suppliers on ebay:
http://www.ebay.com/itm/100PCS-0-2ml-Graduated-Pipettes-Dropper-Polyethylene-for-Experiment-Medical-NI5L-/400685905676?pt=LH_DefaultDomain_0&hash=item5d4abdb70c
But I will wait to see if my guy restocks, if only because I want to use the same source, since I just checked it out with a small order, already.
I was puzzling over what the ad meant by "graduated". Then I noticed the single line on the pipette stem. Just to say that if that is the .2ml line, that has nothing to do with using it for glue. I try to fill the whole thing as full as possible, at least with super glue.
