Stickley 89-516 Questions *LINK*
mdclor
I want to build a pair of nightstands inspired by the book table at the below link. I have a drawing in Bob Lang's book Shop Drawings for Craftsman Furniture, but it doesn't address two questions I have.
First, there is a cross grain situation since stock for the shelves is at 90* from each other. Is that an issue? I will use qswo which is very stable, but it still moves somewhat.
Secondly, the shelves appear to be captured between the legs. Should I leave a small gap between the shelves and the legs to allow for movement or should I make a small stopped dado in the legs to conceal the gap and still allow for movement?
Has anyone made one of these tables that can provide first hand experience?
TIA
Stickley Book Table
Re: Stickley 89-516 Questions *LINK*
Re: L. & J.G. Stickley 516 Questions *LINK*
Bob Lang
When I wrote the book I left details like that fuzzy because, as you note, there are a couple of ways to do it. Even though the shelves are at 90 deg. to each other I wouldn't worry, especially if you use quarter sawn material. The shelves aren't contained across the grain, the worst case would be something opening up and showing a gap where the shelves meet the legs.
If you notch the shelves, and the legs and shelves both shrink a little the gaps would be more visible. If you bury the entire corner of the shelves in the legs you would be removing quite a bit of material from the legs. I would recommend a little of both; cut shallow notches in the legs, 3/16"-1/4" deep and also cut the corners of the shelves to fit. With that scenario if things shrink the only place a gap would open up would be on the inside of the leg where the front of the shelf tucks into the notch.
It also looks like the current Stickley production has left out the interior vertical dividers. Some good photos of an original can be found here:
http://www.daltons.com/l&jg/l&jgsold/ljg-book-table.jpg
Bob Lang
http://readwatchdo.com
question
Please explain middle picture from bottom row of pictures. I don't know what part I am looking at. May be bottom of a leg? If so, it is not like the bottom of any leg I have seen before, which suggests something to learn........
mdclor
Bob, thank you! Yours is a simple solution that I should have realized myself.....
Also, thank you for the pix of the original. It looks like the tenons in the legs were pegged and that they put about a 1/4" round over on the legs.
I agree that the current Stickley model doesn't have the dividers. They wouldn't be needed in the 21st century because nobody has physical encyclopedias any more and wikipedia weighs almost nothing. lol
Now, I have to start milling stock. :)
Merle
Re: question
Bob Lang
Hi Bill,
Yes, that's the bottom of a leg. The hardware is a metal glide on the bottom. Here is a link to a better picture:
http://www.daltons.com/l&jg/l&jgsold/book-table-det3.JPG
if you go to their home page, then to "Sold Archives" there are a lot of good detail images of Stickley pieces.
Bob
